Question about Samsung LE40B650T2 40 in. Full HD Crystal LCD TV
TV will not switch on at the remote or on the set, the red light flashes and clicks but the picture does not come on.
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, red light blinging codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 04, 2009
Green light blinks 7 times on flat screen before turning red. there is a picture for 5 seconds
Good morning
Take the remote and find set up and picture. Try to adjust the brightness and see if you do not get rid of the green light.
all the best
kolbrun
Jul 08, 2012 | Televison & Video
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Phillips 32" tv stuck in standby mode
thesupply is not responding
take your tv for repair
let them check power supply
semi conductors, transistors, zener diodes, an dfuse resistors, also check the switch contact,
and fuse,
Dec 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Sony tv wont start up???
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Samsung LE40B650T2 40 in. Full HD Crystal LCD TV Logo
177 people viewed this question
Jerry Greenberg
Jerry Greenberg
