Question about Sony Cyber-Shot DSC-S40 Digital Camera
When I turn it on to take pix. the lens goes in and out and the screen goes black and give a message to turn off and on again
    Champion:
  • 205 Answers
The unit is jammed, please seek a profession repair from MFG good luck
Posted on Jul 03, 2009
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
Aug 27, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
I have a Sony KP57ws500 that the screen turns green and then goes into standby. then when in standby the standby light flashes eight times then pauses and then flashes eight times again in this pattern...
This is a simple fix and not hard to do, first you must get the speaker grill off, usaly two screws on the bottom and they might be hidden under to caps, then remove the acsess cover from the front. From there you should see a control box with six controls, three on top of three,,,,One part label "screen" the other "focus" now turn the set on and tune to a input that HAS NO SIGNAL this should give you a black pix, probley not now but it's supose to be black. Now turn the ones marked screen , one at a time counter clockwise just a little to get the pix compleatly black, now starting with one color turn the control slowly clockwise till the color just appears then turn it back down till it just disapears (Black) do this for all three colors Now the set should runn
Dec 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Cant open pix messages in my inbox!
taken out the battery or ur mobile for few minutes and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Casio G''zOne Type S Cellular Phone
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Tp5560h
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
Feb 07, 2008 | Toshiba TP55H60 55" Rear Projection...
FUJI FINEPIX S7000
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Jan 22, 2008 | Fuji FinePix S7000 Digital Camera
Fuji Fine pix F470 digital
Shoot, I have the same problem and posted the identical question along with this one. I'll respond her if I hear anything.
Nov 24, 2007 | Fuji FinePix F470 Digital Camera
NECVOX RE-8169DVD ' No Disc' Error Message
Hi
I think you can see the lens of the DVD's laser.  If so get some glass cleaner, and a Q-tip.  Dampen one tip of the Q-tip with the glass cleaner and clean the laser lens.  Use the dry end of the Q-tip to dry the lens
Oct 31, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Sony Cyber-Shot DSC-S40 Digital Camera Logo
170 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
