Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer works great. Refigerator not cooling
We're thinking the damper is not working properly in the refrigerator.
    Problem Solver:
  • 15 Answers
You need to check the compressor and gas pipes.
Posted on Jul 03, 2009
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Hi Side by side refrigerator not cooling down. Freezer seems to be not freezing. refrigerator compressor is running. Freezer damper wide open on a setting, refrigerator turned up to 10, running but not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jkkfj
Jul 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
The refigerator unit will not cool lower than 60 degrees. Freezer works great!
Check to see that the opening between the freezer and, refrigerator box is not blocked and, that the evaporator fan is running.
Jul 02, 2010 | Refrigerators
My freezer is working, but my refigerator is warm and not working. The freezer does have a build up of frost that usually isn't there.
this is usuall a defrost sensor,timer or heater issue.
also check the evap fan and make sure it is working properly.depending on you type there may also be a damper control issue
Mar 18, 2010 | Refrigerators
The freezer is working but the refrigerator is not cooling at all?
the air to cool the refrigerator section comes from the freezer section through a damper.you have to check for air flow thru this damper to see if its frozen or closed. if the refrigerator is not going into defrost that will give the same problem.you could try unplug refigerator for a while ( 2-3 hours )and see if that helps
Jun 11, 2009 | Refrigerators
Freezer ok, but refigerator is warm
first check to see if the controls have been changed,
one of the dials control overall cooling (freeser) and the other controls a damper that allows cold air from the freeser to travel to the refrigerator.
the other solution could be that there is something in the freeser, food or ice blocking the vent.
one other possibility is that the damper is stuck or frozen still.
if your freezer is ok, it is not a serious problem
May 26, 2009 | Refrigerators
Refigerator / freezer not cooling properly
You have a bad defrost heater.
READ THIS PWEASE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Amana Refrigerators
Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Oct 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
137 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
