Question about Pioneer CDX-P1280 12-Disc CD Changer
Cd magazine will not eject,power is connected any soloution
    Champion:
  • 205 Answers
Try holding eject as you turn the unit on? should clear any cd's in the transport then try ejecting. Good luck
Posted on Jul 03, 2009
My 2000 SL500 6 CD cartridge will not eject The player works fine but I want to put in 6 new CDs and cannot get the cartridge ejected
There probably is a CD hung up between the magazine and the player mechanism. There is no easy fix. You will have to remove and disassemble the unit to get access inside. Once everything is back in place, apply power and try to eject the magazine. Otherwise, you may get the unit reinstalled only to find the magazine is still stuck.
Mar 27, 2017 | Mercedes-Benz S-Class Cars & Trucks
Remove CD Magazine - No power to unit!
u need to re-connect it in order to remove the magazine
Jun 15, 2008 | Sony CDX-646 10-Disc CD Changer
Eject cd magazine
At downside of the music center, right corner, there is a "manual eject system" indicator. just push inside slide to upward with a thin screw driver and your magazine will be ejected..
Jul 03, 2013 | Bose Lifestyle 25 System
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
How do I remove the CD magazine from a kenwood kdc-c462 which is out of car & has no power?
I had the same unit, with the same issue. Unfortunately, There is no way to eject the magazine without power to the unit. I took the unit to a stereo shop where they plugged it into a control unit (powered off), powered up the system and ejected the magazine for me.
Sep 05, 2009 | Car Audio & Video
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Pioneer CDX-P1280 12-Disc CD Changer Logo
404 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
