Question about HP PSC 950 All-In-One InkJet Printer
I've tried to use my copier and it continues to say Warming Up. I have shut down and restarted but it continues to say the same and won't copy.
  • HP Master
  • 1,684 Answers
We have found that usually the 'Scanner warming up" error is caused by dirty scanner glass and mirrors. We have a page explaining the problem and the step by step solution to the error. Check out our page at:
www.ccl-la.com
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 03, 2009
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
Side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 01, 2012 | T-Mobile Cell Phones
It's says it's brewing and the water will go into the "warming chamber", but then it like freezes and the Keurig won't do anything. It just continues to say brewing, but nothing...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101 ./.,.,
Aug 13, 2011 | Keurig Platinum B70 Coffee Maker
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 21, 2009 | Xerox Office Equipment & Supplies
I have the above printer
Most likely the fuser unit isn't warming up try shut down and restart of the printer but normally replacement fuser required.
Thanks J
Jan 09, 2008 | Brother HL-2040 Laser Printer
Copier is showing warming up but will not start
the fuser unit has ceased to heat...it has a bad heater. the fuser is a hollow metal roller that usually has a powerful light inside to heat the metal. a continuity test can detect
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
HP PSC 950 All-In-One InkJet Printer Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
