SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
SOURCE: I have a compressor # SSR-EP75 I would lioke to
ingersoll has a web site to down load manuals and parts list, i coulnot get in you probably have to be a dealer to access, but here is the web site www.irtechpubs.com do a search and find your nearest dealer then have him go to the website and down load the manual for you and have him e-mail it to you, also check your serial number i could not get anything to match that number in my search hope this helps
SOURCE: Have a SSR-EP100 air compressor that shows
Try to reset the main motor and fan motor over loads by pushing the reset on the overload it self, Then reset the controller. If the error resets, before starting. put a clamp on amp meter on to L1 or L3 motor lead which is located in the compressor electrical box . Then start and observe amps when unit is making air fully loaded. Once you know how many amps at full load the unit is pulling ,look at the overload setting on main motor overload and see if it is approxmately 10 amps above the max amps being pulled.If not set it about 10 amps above your max load amps.
