Welcome to the real world. Fading receipt print is chronic. In this high-technology world, the only reason I can think of for using that fading, heat-produced print is to rip off the customer.
*No returns or warranty without receipt*. Months later you manage to find your receipt but it's so faded it's unreadable. A lot of good it does you but it sure helps out unscrupulous retailers.
There needs to be a law that receipts last ten years...
You can press the "Reprint" button (second from right purple button) to reprint the last receipt. You can also print any receipt that hasn't batched yet (normally from the current business day) by entering the receipt number. You can guess the number if you don't know it. Number 1 is the first transaction of the day, number 2 is the next one, etc.
If for some reason your transactions from the previous business day didn't get sent as a batch to the processor successfully, you would be able to print receipts for them. Otherwise, contact your processing company, and they should be able to send you a copy of the receipt.
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution. Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and OFF. To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates. The register will print reports regardless of the receipt state, so the paper roll must be installed. "To issue a receipt when receipt ON/OFF function is set to OFF: If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF function is in the “ON” status."
The following is the method to turn the receipt printing on/off: Receipt ON/OFF function You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and OFF. To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates. The register will print reports regardless of the receipt state, so the paper roll must be installed. To issue a receipt when receipt ON/OFF function is set to OFF: If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF function is in the “ON” status.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
This is an old forum, but thought that I would add a link - http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_VX_807_810_EN_1068.PDF
