Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Cannon Imagerunner 2200 Error COde: E000051-0000
Will not allow printer to come back on after turning off the main power switch
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause: The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
This problem should be handled by a technician.
Posted on Jul 30, 2009
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
CAnnon Imagerunner 2800 Error code: E000002 0000
SIR MY XEROX MACHINE IS PROBLEM ERROR CODE : E000002-0000
MACHINE MODEL : CANNON IMAGERUNNER 2200
Jan 18, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
How do I use the staples in the printer/copier?
Cannon image runner 2200 error code E000002-0000, how do solve this problem
Aug 22, 2009 | Canon imageRUNNER 2200
Canon IR 2200 error code E000002-0000
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
Mar 23, 2009 | Canon imageRUNNER 2200
The cannon imagerunner 2200 shows the error code E000051-0000
Have you worked on the copier or has a service person just worked on the copier? The error code deals with the motor M3 not getting a signal to turn ON. Make sure you turn the copier Off and unplug it from the wall...... Then take the back cover OFF and look for connector J3040-2... The connector is most likely only part way in... Disconnect and reconnect it... Also, make sure all the other connection are all in correctly.... Good Luck.....
Mar 12, 2009 | Canon imageRUNNER 2200
Canon Error Code E000001-0002
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Sep 02, 2008 | Canon imageRUNNER 2200
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
1,846 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
