Question about Canon Office Equipment & Supplies
Paper pickup PAPER IS NOT PICKED UP FROM 1ST AND 2ND TRAY AFTER I HAV ECLEANED THE ROLLERS PROPERLY.
    Scholar:
  • 175 Answers
Does it move the paper at all? If you have more than 2 drawers do other drawers work? Does bypass tray work for feeding paper? If paper does move does it always stop at same place?
Posted on Jul 04, 2009
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Keeps telling there is a paper jam
This particular 'paper jam' error on the Dell 3110/3115/3130 can often be caused by the paper not being picked up from the paper tray. The printer 'expects' to 'see' the paper pass various sensors during it's path through the printer. Each one has a 'time window'. If the paper is not seen to pass sensors at the correct timings, a paper jam is assumed.
Now - to cure the problem.
Just cleaning the (3 identical) pickup/separation/feed rollers in the paper tray area could be enough (they get a build-up of paper dust - can affect their effectiveness).
One of these rollers wears much quicker than the rest, and gets a pronounced flatspot. Replacement rollers are available via 'that' well known internet auction site.
Feb 05, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
The samsung ml 2250 printer doesnt pick up the paper out of the paper cassette. It works someteiimes but mainly the paper is not picked up at all and you hear the noise like it wants to pick it up but cant...
Hi there,Don't think its the clutch. I would rather say its more a problem of the paper not getting pushed up against the pickup rollers so you could try stretching the spring a bit and see if it helps.. What you also could try is removing the tray and bypass the paper sensor and see if when you print the pickup roller does turn.
Regards
Jul 28, 2011 | Samsung (ML2250S3XAA) Paper Cassette for...
My copier will not pull the paper through to make copies it seems to want to jam -up ,when the paper start through
There are a couple of possible issues here. First, if the unit isn't new, the paper pickup rollers may have picked up 'chaf' from grabbing paper which over time reduces the ability of the rollers to grab paper. The 2nd option is that if the copier is older, the pickup rollers have dried up which reduces their stickyness and ability to grab paper. The 3rd option is that if you live in a very humid climate, the paper may have absorbed humidity, which can keep it from curling in the correct direction as its being pulled through the printer/copier.
Jun 20, 2011 | Computers & Internet
Paper feeder does not feed papers properly.
Remove the paper tray and check the pickup rollers that are located on the underside of the fax, just above where the paper would sit when the tray is installed. If they are smooth this is a sign that they are worn out. Newer pickup rollers are very grippy. A quick temporary fix would be just wiping any grime or dust off with a damp cloth.
May 20, 2011 | Samsung Office Equipment & Supplies
Says out of paper and is not out of paper
Most of the time, paper feed issues have to do with two sets of rollers in your machine that are responsible for paper pickup and paper separation. (It sounds as though you may have a "pickup" issue).
Turn off the unit. Unplug the power cord. With the bottom paper tray removed, you will be able to see these rollers hanging down toward the front of the machine when you look inside where you removed the tray.
The pair of rollers are the pickup rollers. The single larger roller is the separation roller. Check that these rollers are not dirty.
Clean the pickup rollers with a wet, hard, lint-free cloth; the separation roller with a wet, soft, lint-free cloth. Clean horizontally along the rollers. Turn them around a little at a time to get at the entire surface.
You may also want to clean the pad in the paper tray. Use a wet, hard, lint-free cloth and scrub the pad horizontally.
Replace the paper tray. Plug in the unit.
Jan 22, 2010 | Brother HL-5240 Laser Printer
Paper pickup problem
Can you be more specific about which canon copier you have. There are different feed rollers in different copiers. A short term fix is to clean the feed rollers. You will have to remove or remove the paper tray(s). depending on which copier you have. Some type of dry cloth (free of any residue/I use white dry shop towels) and a little rubbing alcohol will usually get you going again. You should be able to see the feed roller. Just clean it all the way around the roller. Use the alcohol sparingly, you don't want any liquid dripping inside of your copier.
The feed rollers also wear out. Once they get to smooth, they may no longer pick up the paper. If the rollers are removable, some just snap out, you can even lightly rough up the surface with a really fine emory cloth.
Feed rollers wear out and eventually reach a point where they must be replaced. The more card stock that you run through your copier, the fast they wear out.
Hope this helps. If you look inside and are confused what the feed roller is, then your best best is to call a copier repairman.
Jun 21, 2009 | Canon Office Equipment & Supplies
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Constant paper jams. Paper gets stuck. Takes more than one piece of paper at a time.
needs servicing of paper pickup roller and pad separation. Open the paper tray and check for paper dust on pickup rollers Clean the rollers and separation that is fixed in the tray itself using damp cloth. hope this will help
Feb 05, 2008 | Lexmark E238 Laser Printer
Hp colouer laserjet 4500n printer 2nd paper tray dont work when i clear the printer memory it work properly for few day in this printer an error shows drum life low change the drum and tool kit
I would definitely suggest ordering the drum life kit and replace that. A lot of times the tray comes undone from the paper tray holders causing the rollers to not be able to pickup paper. Be sure all the plastic holders are snapped into place on the right paper size setting and check the rollers for dirt, glue or wear.
Jun 07, 2007 | HP LaserJet 1020 Printer
93 people viewed this question
old marine
old marine
