The cold water enters the machine a just above a
The cold water enters the machine in a stream just a little more than a drip. The water is coming thru the hoses fine. The hot water enters the machine just fine.
    President:
  • 3,113 Answers
You may need to replace the water inlet valve then.
Posted on Jul 03, 2009
I have a 6.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? The call out fee is $100 and $20 per 10mis ...
The water solenoid valve may have gone bad and is allowing water to enter. Turn off the cold water shut off valve at the wall to immediately stop any water from flowing. What is your machines model number?
Jan 15, 2015 | LG Washing Machines
Why does coffee come out while pouring in water its a bunn 10 cup coffee maker
The Bunn has a little stopper that closes the water drain port in the reservoir while the lid is open. You can see a little white plastic pin protruding up out of the grate with the lid open. When you close the lid, it pushes on that pin which causes the stopper to lift off the drain port, allowing the water in the reservoir to enter the heating tank.
If water is entering the coffee basket BEFORE the lid is closed, then something is wrong with that little stopper. It may have a chunk of debris on it preventing it from sealing, or it may be deteriorated, torn, disconnected, etc.
Only way to know is to remove the the screws in the grate and pull the top off exposing the reservoir, and the stopper assembly. The little plastic flapper disc should be seated in the reservoir drain port. It should be relatively flat (not wrinkled) and covering the drain port completely. Test it by pouring some water into the reservoir. If it drains out without you activating the stopper, then a repair is needed.
Move the lever up and down and check its operation. The arm must move freely and close when released. There should be no dirt or debris on the sealing surface of the flapper nor on the sealing surface of the drain port. Gently clean with vinegar as necessary. If the seal is damaged, then a replacement is required.
Nov 29, 2014 | Bunn 10 Cup Home Coffee Brewer
I have a cold water leek from below, seems to be running down side of salt container
white is calcium possible cold water solenoid leak check where hoses connect in back top
Feb 27, 2018 | Hotpoint 23 in. BF41 Built-in Dishwasher
When I want to run cold water only, water just dribbles out and does not flow properly? That is when the dial is on cold/cold position. Is there a blockage somewwere?
I am not a repair person but I have this exact washer, and this problem all of the time. You probably have sediment blocking the water from coming through the cold water hose. Turn off the main water supply valve where the hoses are connected, then disconnect the cold water hose from this end ( not the end connected to the machine). There probably is a little plastic filter with a rubber gasket on the inside of the end of the hose. Remove this filter and gasket, noting how it is in there so you can replace it exactly the same way. Clean out this little filter in sink to remove all sand, dirt, sediment. Replace filter back in end of hose and connect back to water valve. Turn main valve back on. This should make a huge difference in the stream of cold water that comes into your machine. I have very hard well water with a lot of sediment and need to do this procedure about once a month. However, we just got a filter attached to our well holding tank so hopefully this will catch the majority of sediment before it goes through the house and into my washing maching hoses!.
Good Luck!
Feb 22, 2011 | Maytag Performa LAT2500A
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cannot get cold water to come into the washer
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Jul 14, 2009 | Whirlpool Washing Machines
There is little to no water pressure in the cold
hi,
look into the inlet valves of the washing machine(where the hose connects to) and see if you can see inlet screens in the inlets, they are removable and you can can clean them but be very careful popping them out as they can get bent easily, hopefully that does it
J
Jun 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leak inside car
Try check the AC water outlet hose there must be a leak from there.
Apr 30, 2009 | Mazda 626 Cars & Trucks
NO COLD BUT ONLY HOT WATER ENTERS WASHER
here's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Apr 01, 2009 | Maytag Washing Machines
Cold water leaking in washer tub
Replace your fill valve and you will be back in business.
May 27, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
