Question about Samsung SWA-4000
I'm having problems getting my swa-4000 system to work tried the code and holding down the reset button i have an ht-x715t system and the tx card is in right any idea's thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 03, 2009
Trying to bypass module for wwireless speakers.. Is there a code??
No. If the system came with the wireless rear amp, then it will not work without it.
Jan 18, 2013 | Samsung Wireless Receiver Module Swa-4100...
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
Will a swa 5000 tx card fit a ht-tz225 home theater ststem
Unfortunately it would appear not. I just bought an SWA 5000 for my HT TZ 225 home threatre system as it would seem the SWA 4000 has been discontinued - the HT-TZ225 refers to the SWA 4000 doesn't it.
The tx card that accompanied the SWA 5000 was too big and did not fit in the back of the DVD player so I will have to return this to the retailer and keep looking for an SWA 4000 . . .
Unless anyone has another solution.
Apr 28, 2010 | Samsung Audio Players & Recorders
Can a new tx card be used in a swa-4000
where can you get a tx card from, because i need one and yes it can as long it is for that specific wirless module ?
Jul 09, 2009 | Samsung SWA-4000
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Dec 13, 2008 | Samsung SWA-4000
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Nov 08, 2008 | Samsung SWA-4000
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
Samsung SWA-4000 Logo
2,086 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
