A standard tv not a flat screen and when its playing a dvd it has a greenish tint like appearance to it in the left hand corner of the tv? what issue am I dealing with here?
Degaussing posistor resistor fail. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
SOURCE: TV has a greenish tint
first off are there any speakers close to the tv ?. if so move them secondly your degauss circuit may need servicing.
SOURCE: Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
SOURCE: Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
SOURCE: the picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
