Question about Sony Xplod XM-554ZR Car Audio Amplifier
Can I Add two 12" subs and 2 pairs of 6"x9" speakers to my amplifier
I have a 10 year old pioneer 4 channel class A amplifier GM-X904 in good condition which I had got for $450 and gives me ample power to drive a pair of pioneer 6"x9" speakers and a 12" pioneer sub from my car's headunit. I was wondering if I can add another 12" sub to the existing setup. Please help me on this I have seen a bench test on this amp and it did:
161rmsx2@4ohm bridged
I cannot remember the test voltage though.
Other than that I can tell you from digging through the Pioneer catalogue that this unit is from 1996 and specs are:
Continuous power (20-20kHz, 0.04%THD
-2/3/4ch capability
-no current limiting
-S/N ratio 105dB
-frequency response 10-80Khz
-variable low pass filter 50-120Hz, -12dB
-variable high pass filter 50-120Hz, -12dB
-independent front and rear input gain controls 400mv-2v
-gold plated dual inputs
-gold plated thru-put terminal
-PWN power supply
-fan cooling system
-high speed mos-fet power transistors
-high performance balanced isolator circuit
-made in USA
  • 306 Answers
Re: Can I Add two 12" subs and 2 pairs of 6"x9" speakers...
You could try to wire the subs in a series which all positives are connected in a line from amp to pos of sub to pos of other sub , same for the neg.
heres sum extra reading materials:
Posted on Nov 12, 2007
0 characters
3 Points
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    Ihave a gm-d84004m 1200 watt amp whatsize amp wires should i use
    if you are talking about the power and groung use atleast 4 gauge for the subs i usually use 10-12 gauge
    Jul 10, 2010 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
    Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
    165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
    Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Pioneer GM-6200F amp appears to have blown, but fuses are intact
    I have used Pioneer before but have not run
    across this before.sounds like you may have
    drove it a little to hard, and and zap one of your amps inside.Take the top off and look
    around and smell.
    Maybe This Will Help
    Sep 09, 2009 | Kenwood Excelon KAC-X811D Car Audio...
    Pioneer car audio amp GM 6300F (new)
    Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
    Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
    What amplifier should I use for 2 650W Subs?
    HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
    Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
    What are the correct spaekers for the gm 5100t ?
      CEA-2006 Compliant Amplifier Power Standard:
    • 125 Watts x 2 @ 4 ohms <= 1% THD+N
    • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
    • 75 dBA Signal-to-Noise Ratio
    • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
    • 2 Channels
    • Continuous Power @ 4 Ohm: 125W x 2
    • Continuous Power @ 2 Ohm: 190W x 2
    • Continuous Power Bridged @ 4 Ohm: 380W x 1
    • Frequency Response: 10Hz-50kHz
    • THD (1kHz, 4 Ohm): <0.015%
    • Signal to Noise Ratio: >95dB
    • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
    • Oversized Screw-Type Power/Ground Terminals
    • 2 Channel RCA Inputs
    • Speaker Level Input
    • Hi-Volt Input Level Control (200mV-6.5V)
    • Bass Boost (50Hz, 0/6/12dB)
    • Selectable LPF (80Hz, -12dB/Oct.)
    • Pioneer 1-Year Warranty
    I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
    Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
    Support Question about RMS
    you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
    i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
    if you have any questions email me at
    Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
    Hi Trim God,
    I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
    Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    214 people viewed this question
    Top Sony Car Amplifiers Experts
    Tygh Duval
    Tygh Duval
    Are you a Sony Car Amplifier Expert? Answer questions, earn points and help others
