Question about Pioneer DEH-2700 CD Player
We bought a Volvo with the 2700 installed. But you have set the presets and clock up every time up start the car. you turn the key off it completly loses its memory. This is driving my wife nuts please help.
    Problem Solver:
  • 3 Answers
Are you sure you connected the correct wire (Yellow) to the constant +12V?
Hope you fixed it by this time.
Suleiman
Posted on Mar 21, 2010
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
My 2008 Ford Escape Owner's Manual says to re-set the clock just hold the "clock" button and the time will start flashing so you can then set it. This does not happen. If I recall correctly I...
Making sure the radio power is on,
To set the time, press
CLOCK. The display will read SET
TIME. Use the memory preset #s to
enter in the desired time, hours and minutes. The clock will then begin
from that time.
Nov 19, 2010 | 2008 Ford Escape
Radio resets when car is turned off
There is a yellow wire in the harness coming out of the head unit, this should be connected to a constant power. This circut maintains power to the head unit for the clock and memory.
The red wire should be connected to a source that is turned on and off with the key switch.
Jun 01, 2010 | 2003 Ford Focus
How do you program channel and set time on clock?
2001 - 2002 Models:
Press the "CLK" (clock) button until the time is displayed, then press and hold the "CLK" button for at least 3 seconds until the time indicator blinks.
While the time is blinking. turn the rotary encoder to increase or decrease the minutes.
Once you've set the clock it will automatically return to normal operation after 5 seconds.
Pre 2000 Models:
Press and hold the "CLOCK" button for 3 seconds until the time indicator blinks.
Press "PRESET 5" to adjust the hour setting.
Press "PRESET 6" to adjust the minutes.
Press "CLOCK" again to exit clock adjustment mode
Hope this helps.
And to set the stations get the station you want and hold down one of the buttons from 1-6 to progream the station. you need to hold the button for about 5 sec.
Jan 22, 2009 | Alpine CDM-7833
Clock - no display
If there is no display, you could check the fuse box? To set the time manual page 38. number 13. twist and hold to change the time.
Oct 25, 2008 | 2006 Volvo S40
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Pioneer DEH 435 CD player
Same as all Pioneers. With the car on or in ACC position press and hold SOURCE until the radio turns off. Press and hold FUNC to enter the menu. Use the four arrow keys to navigate and make changes.
Nov 30, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
How to reset a deh2700 clock
I HAVE FIGURED IT OUT..
You have to hold the audio button in the top right corner till the time blinks, then use the arrows to set the time and then hold the audio button again when finnished.. AND YOUR DONE!!! It makes no sense why you wouldnt have to hold the clock button like most any other radio is BEYOND ME... screw all this hidden stuff..
Jun 19, 2007 | Pioneer DEH-2700 CD Player
How do I set the clock and preset stations.
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
Apr 10, 2007 | JVC RC-QN2 Cassette/CD Boombox
Pioneer DEH-2700 CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
