Question about Gateway M305CRV Notebook
Help when i press u/i/o/p/j/k/l/m. numbers or symbols come up instead unless i hold down fn. what have i done wrong as you can tell i am a novice
  • Anonymous Jan 05, 2009
    had the same problem - thank you!! Easy when you know how eh, was tearing my hair out!
    Scholar:
  • 46 Answers
Everyone has to learn! Don't worry. Your NUM lock is one. You should see a light on the computer that looks like a little lock with a number in it (typically the number 9). If that's on, the number keypad in the center of your keyboard will act like a ten-key keypad that you see on the right side of large keyboards. Just hit the Num Lock button on the top right of your keyboard to turn it off.
Let us know how it turns out or if you have any more trouble. Keep learning! It's your best asset.
Posted on Nov 10, 2007
Thanks ..... all the right.....
Posted on Nov 10, 2008
How do I use the blue coloured symbols below my number keys?
when keys have 2 options on them you either hold down the shift button to change keys or the FN blue button to use the blue symbols ( to sum up,hold FN in and press a blue symbol,hold shift in and press a key with 2 options on it ) FN button is usualy bottom left of keyboard
May 30, 2015 | HP Computers & Internet
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
When trying to type and using keys uiopjklm,unless i press the fn key whilst pressing the secected key,a number is typed instead .
Try holding the Ctrl and Fn key down together and then press the Ins(Num LK) key. This should revert the keys back as normal.
Sep 15, 2010 | Computers & Internet
Cannot use letters of my laptop unless use fn key but not capital
You need to press the NumLock key to get the keyboard to get back to alphanumeric - it has a symbol of a lock with a number 1 on it. A LED should also go out/icon in your tool tray should disappear as well.
Jul 05, 2009 | Acer NSK8458AN Keyboard
Keyboard types upper case digits instead of lower
It sounds like you may have turned on the calculator function - Does one of your F keys have a light on - F10 or F11, if so Press Fn and the key that is lit up.
May 21, 2009 | Advent Netbook
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Ibm t30 keyboard stuck in odd mode
You've activated Euro mode. This is toggled by pressing holding the Fn key plus an Fkey that has an icon in the same color as the lettering on the Fn key that looks like the Euro symbol. Press the Fn key plus the Euro key to toggle out of Euro mode.
Regards,
Worldvet
Aug 03, 2008 | IBM ThinkPad T30 2366 Notebook
Gateway M305CRV Notebook Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
