Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I can get water out of door but water is not filling ice cube tray.
If you don't have water flow into your ice maker at all:
1. check if the shut-off arm is fully down.
2. check if some ice is stuck inside the ice maker.
3. If you both are normal, you might have a control vaulve problem
If you have water flow into the ice maker, but there is not enough. You can adjust the time of the water flow by adjusting the screw:
http://www.fixya.com/support/t2043875-water_overflowing_in_ice_maker
Posted on Jul 08, 2009
  • 4,070 Answers
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If you get water the ice maker is the problem.
Posted on Jul 03, 2009
3 Suggested Answers
SOURCE: KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Posted on Dec 05, 2008
SOURCE: ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Posted on Jul 25, 2009
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
My ice maker receives water after it has filled and frozen ice cube tray, water in door is a very weak stream, where do I find a correct water line routing diagram, already replaced water valve?
A plugged water filter will cause low flow. To identify which solenoid operates the water flow on the door have a helper operate it while you feel for which one is working. It's possible you crossed the lines. That would explain water running over frozen ice cubes.
Aug 29, 2017 | Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
Water comes out the cubed ice portal and does not fill ice tray
scottt57 could have switched the wires on the solenoids. try switching them and observe where the water would come out..
Feb 12, 2008 | Refrigerators
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
337 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
