Question about Cell Phones
Bluetooth pairing I can not get the Bluetooth to pair with my Car.It recognizes it but will not pair..Is the pairing number wrong?
  • 389 Answers
The default pass code for that should be 0000
Posted on Jul 03, 2009
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Cannot pair samsung alias phone to motorola bluetooth
Hi,it's very easy to pair.
First get one of the phones blue tooth on, and pair with the other phone .
When pairing,it will ask you for password key, you can use any number of your choice, but it has to be a four digit number.(Any four digit number) eg 1234,1111,0000 etc.
Ones you type in the code you want to use for pairing, it wlll ask you on the other phone you are trying to pair to type in that the same code and your done with pairing you, Ones the other phone recognizing the phone you paired it with you can now send data to each other.
If it does not pair immediately, restart the phone and try again.
Good luck.
Sep 27, 2010 | Verizon Communications Samsung Alias Cell...
My iPhone recognizes my Emerson 227 bluetooth but pin numbers will not connect using recomended codes 0000-1111-1234-9999 are there any other salutions my iPhone is 3g
Put the headset into pairing mode. First turn it off. Turn it on and hold the powerbutton down until the bluelight is not blinking then pair using 0000 as the pin.
Aug 21, 2010 | Emerson EM227 Bluetooth Headset
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
Sep 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Jan 28, 2009 | Cell Phones
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Cell Phones Logo
83 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
