Extra large capacity front loader
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter
Vent:
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils:
This is the most likely cause.
Click links below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1
There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: Maytag Dryer model # LDE313
at the bottom of the front panel you have two screws, remove those and swing out at bottom and drop off
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
SOURCE: Dryer is making a banging noise? Sounds like
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
SOURCE: found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
