Question about Pool & Spa
Heater firers then goes out after about 30 sec also knocking out the pilot.
The main question is if the pilot goes out after you turn on the timer or goes out by itself. If it goes out by itself (without turning on the timer) then you need to make sure your thermocoupler and overall pilot generator assembly is positioned directly near the burner. If your pilot goes out when you turn on the timer then your wiring is not correct. You can go directly to the manufacturer for support, they are very helpful. I dont know their number but you can find it on their website. Good Luck
www.scandiamfg.com
Posted on Jul 22, 2009
  • 11,896 Answers
It could be faulty coupler or fuel filter tube. Also pilot valve may not be staying in the up positon
Posted on Jul 03, 2009
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
When furnace kicks on, stays in for about 30 secs and kicks back off
It could be you need to clean the flame censor , check air filter is clean , clean pilot it could be blocked .Check hoses to pressure afr tight and not spilt .
Jan 05, 2013 | Heating & Cooling
Have a comfort glow heater blue flame after it is on for 30 sec or more the flame and ignition goes out i can restart it and it will stay lite another 30 sec or so what can i do
Easy remedy. You pilot safety is dusty. You need to flush it out or blow it out. I use rust buster. It has a long spout on it. I squirt a little bit into the pilot to flush out dust and cobwebs then I blow it out and allow the rust buster to dry. I then relight it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 15, 2011 | Heating & Cooling
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
My reddy 30 heater will not stay lit after starting I have held the switch down for longer than 30 sec but it just want stay lit
thats sounds like a thermocouple problem its located right by the pilote light assembly,,,rod shaped object
May 14, 2010 | Heating & Cooling
Water heater pilot
This is more than likely the thermocoupler. The thermo Coupler is a solid cylinder shape with a point on one end and a thick aluminum wire on the other the tip is situated so that it is in the pilot flame. When it reaches a certain temperature from the pilot it sends a signal for the gas valve to stay open and keep the pilot light. If it does not send the signal the valve closes and shuts the gas off for safety. Solution first make sure you hold button long enough to heat Thermocoupler (about 30 sec) if pilot still goes out then replace Thermocoupler. Can purchase at most hardware stores and all plumbing shops.
If this has been helpful please select a rating. Good Luck and have a Grt Weekend.
Apr 01, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot is lit for 30 secs but when I turn the knob for the big fla
You have a white scale buildup in the gas valve outlet blocking the main gas flow. Take the valve apart and clean it.
Jun 14, 2009 | Uniflame 200209 Open Flame Patio Heater
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Natural gas patio heater
make sure there is no dust dirt spider webs in the pilot hood if u have a nice blue flame coming from the pilot and u held the pilot knob down for at least 30 sec
and it still doesn't work then u have a bad THERMOCOUPLE
Sep 25, 2008 | Heating & Cooling
Pool & Spa Logo
245 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
