Question about Microsoft Xbox 360 Console
My xbox 360 is blinking 3 red lights what do i do
  • 30 Answers
This is the infamous red ring of death, a general failure of the box.
Contact xbox technical support through http://support.xbox.com/support/en/us/nxe/contactus.aspx and they can explain the process for getting it fixed. Be aware this can take around 6 weeks to complete. However it is normally done for free.
Posted on Jul 03, 2009
ryanriopel28
  • 130 Answers
SOURCE: xbox 360
Send it in to Microsoft. They'll fix it for free. "If a customer has an issue indicated by the three flashing red lights, Microsoft will repair the console free of charge -- including shipping -- for three years from the console’s purchase date."
http://www.xbox.com/en-CA/support/petermooreletter.htm
Posted on Dec 04, 2007
SOURCE: fix xbox 360
the famous red ring of death caused by overheating stick a fan behind it!
Posted on Jul 15, 2008
SOURCE: xbox 360 with 3 blinking red light
The xbox keeps blinking the red light and it doesn't show anithyng on the screen.
Posted on Oct 27, 2008
SOURCE: xbox 360
The 3 red light error is a CPU and GPU chip error that overheats.
Nearly all of these problems are caused by overheating and you can fix them yourself.
I used the blog below to fix mine and it took about 40 mins:
http://xbox3603redlights.wordpress.com/
Posted on Nov 02, 2008
mycharmingli
  • 389 Answers
SOURCE: my xbox 360 get 3
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new. It is a heat sync problem that has to be repaired by someone with indepth electronics knowledge. THERE ARE OTHER EASIER ISSUE TO REPAIR I JUST NEED MORE SPECIFICS AS TO PROBLEMS EXPERIENCED. try this link as well http://www.zimbio.com/Xbox+360/articles/332/One+Light+Two+Lights+Three+Lights+More
Posted on Nov 12, 2010
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
3 blinking red lights
u my friend hav the 3 red rings it just means that u need 2 let ur xbox rest 4ahale ur lucky its not tha ring of death
Dec 20, 2009 | Microsoft Xbox 360 Console
My xbox 360 has one red blinking light and will not play ,the greenlight is on.
rrod red ring of death. i believe if there are three blinking lights, microsoft will fix for free, but i don't know what one means. go to xbox.com and you'll find the answers you seek
Aug 19, 2009 | Microsoft Xbox 360 Elite Console
Three red light`s on xbox 360 console how can i fix the problem
How to Fix Xbox 360 3 Red Lights
Appearance of the three blinking red lights on your Xbox 360 game console is a familiar problem and in this article I will try to offer some solutions to rectify this nagging problem.
The 3 blinking red lights point to an internal error and might be ascribed to common breakdown of hardware.
Try out this simple fix if you like:
Step one will involve removal of memory units and hard drive.
At step 2, under the system blade run the INITIAL SETUP.
At step three involves declining the insertion of memory unit or HDD prompt offer with a negative reply when the prompt creates the automatic offer.
Finally you need to sync the controller & pop in a game.
Due to the widespread occurrence of the three red light fault, Microsoft is offering a new 3 year free warranty.
Aug 02, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 with 3 blinking red light
Oct 19, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
I get red rings when i turn on my xbox 360
Three red blinking lights
This means your 360 has had a hardware failure. If you have purchased your XBOX 360 within the last 3 years you will still have free warranty on it. Call XBOX customer support and they will help you with replacing/repairing your Xbox 360. 1-800-4MY-XBOX. (1-800-469-9269)
Hope this helps :)
Feb 09, 2008 | Microsoft Xbox 360 Console
Using the cooling unit for the XBOX 360, we get 3 red lights
make sure that the cooling unit is connected correctly, if not the three red rings of death will turn on. Also make sure that the cords are not in away loose. if this dosen't salve your problem, read the manual.
Nov 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
175 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
