Question about Bissell 3750 Lift Off Bagless Upright Vacuum
The plug and socket also burned on mine
Is There a Place where we can purchase the plug and socket ?? in case Bissell does not send me a re-furbished vacuum ..
  • 120 Answers
Bissell wont sell the parts you need any more. dont ask me why.
Posted on Jul 06, 2009
Bissell 1630-5 Deep Cleaner Parts need filter Where can I purchase this?
Go on line to Bissell and seek the parts department and purchase from them. If you care to enter the part number of the device you need into the command line of MSN.COM; they can send you to several sites that can fill you needs.
May 10, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell quickwash 1970E for carpets/hard floors won't come on
If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
Mar 28, 2014 | Bissell Vacuums
Bissel vacuum will not turn on
Hello, this is Ava with Think Crucial.
One of the possible causes that your Bissell won't start is that power cord may not be firmly plugged in so you may need to check electrical plug. You may also want to check or replace the fuse or reset the breaker in case there is blown fuse or tripped breaker.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 16, 2012 | Bissell 6594 PowerForce Bagless Upright...
My bissell powersteamer "pro" smell like something
mine has the same problem and i found it was the belt, which broke due to age
Oct 15, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
I purchased a Bissell steam cleaner demo, and I have no working instruction.
Go to www.bissell.com and click on the customer service link and have them send you a copy. If you purchased the cleaner brand new and it had no instructions with it, they SHOULD NOT charge you.
Mar 05, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell vacuum cleaner won't turn on.
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Dec 29, 2009 | Bissell 6594 PowerForce Bagless Upright...
WHAT'S THE EASIEST WAY TO INSTALL BELT?? I KEEP BURNING BELTS.
First check to see if the brush rolls freely with no belt in place. If not remove the brush roll and clean and lube the end caps. If the caps are nylon try to gently pop them off to inspect underneath.
Clean the motor shaft with extra fine wet dry sandpaper, then install the belt around the shaft and onto the brush before engaging the brush in it`s socket. Now use the brush to leverage into place.Check again for free smooth rotation, then replace the cover plate
Sep 06, 2009 | Bissell 3576 CleanView II Bagless Upright...
I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Jun 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 3750-t part
WOW just spoke with bissell, and they are sending me out a refurbished 3750-r. This thing has been sitting in my basement for over 5 months, who would have known.... Thanks Guys
May 07, 2008 | Bissell 3750 Lift Off Bagless Upright...
Male plug needs to be replaced.
I had same problem with my lift-off, i sent email to Bissell explaining what the problem was and where to get replacement parts. They sent me emial back saying they will send me refeb replacement vacuum becasue this part has been discontinued (I think there is a prolem with lift-off and Bissell is trying to make it right for their customer without official recall). I did get my fedex lable and i sent entier length of cord from my lift-off back to them. I should be getting my refeb vacuum soon.
---Pete
Apr 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
216 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
