Question about Whirlpool LER4634J Electric Dryer
Whirlpool Senseon dryer GEW9868kq
Heating element is not working. did continuity check and it is good. no volrage is coming in into the heating element. any suggetstions
    President:
  • 1,714 Answers
The element is controlled by thermostats mounted inside the back of the dryer on the air exit box. There is also a contact on the motor that makes when the motor is running. Any of these could cause the problem. Try a different heat cycle, this may help narrow it down.
Posted on Jul 04, 2009
Dryer problems
Do not rule out your control board but there are a couple of heat sensors you need to check. There is one bon the heat coil and one on the air exhaust. you can bypass them both one at a time to verify those are not it.
Jan 10, 2014 | Whirlpool GEW9868K Electric Dryer
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
After replacing the heating element in lte5243dq the thin twin dryer it still doesn't work
http://www.partselect.com/ModelFrames.aspx?ModelID=706288&ModelNum=LTE5243DQ0&mfgModelNum=&ManufactureID=3&Selected=AJ4UQMWK&Position=4&mfg=Whirlpool&Type=&Mark=3
Did you check the thermostat and the high limit thermostat. If not check them for continuity with a volt meter to confirm if they are good or not. Continuity good, no continuity bad. I posted the diagram above so you can locate the pieces in the machine.
Jun 20, 2012 | Whirlpool Dryers
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
My whirlpool ultimate care heavy duty super capacity dryer is not heating at all ,I tested the heating element for continuity , & have none , so this means the heating element is bad?
yes if you do not have continuity that meens the element is bad. just to be sure you may want to double check meter to make sure it is working properly, or check element for visual damage
May 12, 2011 | Whirlpool Dryers
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool Dryers
Whirlpool dryer will not heat
check for continuity at the heater element if thats good check the thermal fuse on the element housing at the top jump it out and if the heat comes on replace the thermal fuse let me know how you make out
Aug 05, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
748 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
