Question about Yard Man Garden
Brand new leafblower first use and it stalled after 5 minutes. tried to re-start and the pull string will not move?
  • 284 Answers
Hopefully unless it is a 4 cycle? you mixed 2 cycle oil and fuel together as one and put it in the fuel tank? you can use a 40:1 mixture 3.2 oz of 2 cycle oil to 1 gallon of fuel 87 octane will work or 89 octane is better.
if its a 4 cycle (10w-30 for oil) and fuel go in a seperate area?check your manual to verify what they would like you to use
Posted on Jul 03, 2009
String trimmer has very few hours on it. After about 5 minutes of running it dies like the switch was turned to off. When it cools off a it will start? Is it the coil or something electrical?
if it is brand new (out of the box new) it will still be covered by warranty
it sounds like there is a problem in the ignition module and when it gets hot it is failing
take it back to the shop or an authorised service agent for a warranty check /replacement
Aug 12, 2015 | Garden
String trimmer
Hi robert
May 01, 2013 | Garden
I have a TROY-BILT Tiller/Edger model 12216. I installed a brand new spark plug, fresh gas and new oil. It started and I even used it to break up a small portion of my yard. By small I mean probably 5...
check gas/oil, if all is good the pull the spark plug, hook the spark plug back up and pull the cord while observing the spark plug for spark, may be the coil. Hope this helps Tim
May 02, 2011 | Garden
02 Chevy Blazerstalling problem after about 45 minutes of driving
vacuum leak? or try the fuel pressure regulator my started stalling then got to where it wouldn't crank. changed the fuel pressure regulator and it ran as if it was brand new
Oct 09, 2009 | 2002 Chevrolet Blazer
Brand new equipment compressor work 5 minutes,
sounds like your slugin oil back to compressor and its over working itself especially cause you have low amprage,you need to pull a vacum on the systemm and bring it down to -25 psi and hold that vac.charge for a good 2 or 3 hrs and then recharge with new freon not the freon that was pull out of system,dont flip jug or try to put any liquid in even know the system will act like it wants liquid just add the gas slowly and it will eventually recoop it charge and amprage should rise to 8.9 to 9.2 depending on the outside temp.note: if this unit is under warranty by manufacture they should replace it due to the fact of a brand new unit that has never ran properly since installed call manufacture for complete waranty details heres the basic warranty this unit comes with and phone # - WARRANTY
Labor Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Parts Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Have more questions? Please contact 1-800-626-2005.
hope this helps
Sep 28, 2009 | GE Quiet-Aire Ductless Mini Split System...
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Starting problem
check auto shut down relay , was it name brand pump ? new does not mean good
Jan 29, 2009 | 1997 Chrysler Sebring
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
119 people viewed this question
Top Yard Man Garden Experts
Phil Walker
Phil Walker
Jim Parker
Jim Parker
john h
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
