Question about British Telecom Lands Phones
I cannot receive incoming calls on my landline bt phone although can make outgoing calls
4 Suggested Answers
SOURCE: no connection outgoing and can't answer incoming calls
I had exact same problem. I tried changing battery but it did not work. Finally, i removed the power and phone line to the base and reconnected after 5 minutes and all the handsets started working.
Posted on Jan 04, 2009
SOURCE: My landline phone won't ring, but I can get and make calls!!
My experience with an old (100+) and newer house is that it is important to make sure your telephone wires coming into the house, and the junction block where all the wires connect, stay clean and dry. If the wires can get damp or dirty, then when that 90 volts of ringing voltage come down the line, it may find a low impedance path. At my old house I had to make sure the outside wires didn't touch the ground or get damp. In my newer house, I discovered the wiring block was near a dryer vent where it got a ton of fuzz on it, plus the moisture, so eventually our phones stopped ringing even though we could make calls and our DSL was not affected. When we exposed and cleaned up the wiring block so that the phone company tech could re-visit us to troubleshoot things, suddenly it started working again.
Posted on Mar 19, 2010
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Posted on Mar 11, 2010
I can't make any outgoing calls, although I do receive incoming calls, it keeps saying the phone number is wrong but I've dialed correctly plenty of times. What is wrong with my house phone?
Does it do with all outgoing numbers or just one?
Sounds like there is a fault with your line. There is a setting at the exchange that bars outgoing calls. Phone your service provider and ask them to check the line and the settings.
Jul 19, 2016 | Cell Phones
Have purchased this producct plugged it in no ringtone no flashing to indicate incoming call have operational line with dialing tone, help please asap as only line into work
I am assuming that you can hear dial tone on the handset, and you can make calls on the phone. If this is correct, then I would recommend contacting BT and getting the phone replaced with one that works. http://www.bt.com/help/home/landline.html
Apr 16, 2015 | BT Duet 210 Corded Telephone - White
Print out incoming calls on landline
Only if you are Law Enforcement and have a reason
Aug 27, 2014 | Lands Phones
Unit around 3 years old. Suddenly will not receive or send calls, although phone rings when there is an incoming call so it has power.. Have checked and the phone line is connected. Our landline phone unit...
yea these phones are ****. choose a different brand if you can afford to. we have to buy new ones yearly. the batteries are as high as the phone.
Mar 03, 2011 | Uniden Cordless Phone
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
Aug 04, 2009 | Nokia N73 Cellular Phone
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Lands Phones Logo
1,017 people viewed this question
Top British Telecom Lands Phones Experts
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
