Question about Vacuums
My hoover elite rewind does not pick up dirt like it should. how do i check for a clog? I can hear it picking stuff up but when I empty the cannister there isn't much in it. today it shut off like it threw a breaker. I let it sit and plugged it back in and it started working again. don't know if the problems are related or not. any suggestions??
  • 120 Answers
Have you cleaned the inside filter? Open the cup hold on to the yellow piece in the center and twist it to unlock (there are arrows on the pieces to show how far to twist). Take the filter out and try to clean as much of the debris off of it.
Posted on Jul 06, 2009
Picks up trash fine but there is no "swirling" in the canister.
If the dirt is not making it to the dust compartment it may have a clog somewhere.
Mar 01, 2014 | Hoover Elite Rewind Bagless Upright...
I have suction through the hose but not when using in the upright position. The problem started once I removed the filter to clean it.
there is a chance that the hose between the ground pick-up and the suction hose is clogged,, this happens when the filter is blocked and all the dirt and stuff only makes it part way up the hose and then settles at the bottom. run a wire coat hanger down the line to break up the blockage.
c...
Dec 30, 2010 | Hoover U5507900 Elite Rewind Bagless...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
I have a Hoover Elite Rewind vacuum. Actually,this is my second one. However, after about 4 months of use, it emits a "sour" smell when I'm using it. I empty the cannister before each use and clean out the...
does it smell like an electrical burning odor? could very possibly be the motor going bad already. ive seen it happen. but if not try freshwave odor absorbing pearls. i carry it in my store and we do have shipping. Truly the only thing you should use to get rid of odors in a bagless vacuum, it wont clog your filters
Jan 03, 2010 | Hoover U5507900 Elite Rewind Bagless...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Apr 08, 2009 | Vacuums
Broken motor on new Hoover Elite Rewind
I only have the number for the hoover service center in Seattle, but they can certainly point you in the right direction of a service center in your area or a customer service rep.
Hoover: 206-367-4425
-R
Aug 28, 2008 | Hoover Elite Rewind Bagless Upright...
Hoover elite rewind with widepath
Check the hose and the dirt inlet for a blockage.
May 27, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
