Question about Saws
Where can I purchase a table saw insert for a powermatic 63 like the metal insert that was original when I bought the saw in 1989. thanks
    President:
  • 1,996 Answers
I would try calling powermatic here. They'll be able to get the part number and let you know whether they have it available, or if it's compatible with currently produced models.
Unless you have the part number from the manual, their web site is hopeless....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
Powermatic manuals
L Luke, closest I could find is May 1983.
http://vintagemachinery.org/pubs/655/6140.pdf
Aug 22, 2014 | Powermatic Saws
What belt(brand/numbers)to replace the one on a Powermatic Artisan 63A Table Saw?
Probably a long out of date question but my suggestion is to purchase a link style belt to replace the old hard drive belt that comes with the saw. It'll deliver more power to the blade, run quieter and work better. I also recommend replacing the drive pulleys while you're at it. Get a couple of balance ones.
You can get a link belt at Rockler or other woodworking outlets.
http://www.rockler.com/1-2-power-twist-plus-link-v-belt
Jun 19, 2014 | Powermatic Saws
Table saw won't start
You can only tell by using a continuity tester or a multimeter and some troubleshooting techniques.
Nov 10, 2013 | Powermatic 1791227K Model 64 10" Artisan...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I am trying to find out how old my powermatic 66 table saw is. serial no is 97661400
On the Powermatic 66's the first two numbers are the year in which it was made, so yours was made in 1997. The second set of two numbers is the model. The last numbers I"m unsure of but its my understanding that they represent the manufactured number, so yours was the 1,400th saw made for that year.
May 27, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Need motor cover for powermatic 66 table saw
I have seen a "buy it now" on Ebay for such a thing. Someone making a vacuum formed generic cover. Looks like it would work, even if it looks like a bubble-boy-solution.
Another solution I have seen is a wooden replica with louvers for ventilation.
Sheet metal would be a solution if you have a break and press to properly form, other wise it looks like you banged it our with a hammer and scrap metal.
I need the same thing and will probably to the wood with a paint that hides the fact...
Feb 25, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Aug 16, 2009 | Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Need a rocker switch for a Powermatic 63 A Artisan table saw part number 6285322
If you want to buy a new one, the Grizzly G1022 Table saw is an exact replica of the PM#63. A owners manual and parts list is available at their website. Grizzly.com
Jan 03, 2009 | Powermatic 1791227K Model 64 10" Artisan...
Saws Logo
85 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
