Computers & Internet Logo
A
Anonymous Posted on Sep 21, 2014
My Acer p 5270 projector is lock .A black box is displayed . There in > a password ( number ) are putting saying . How to enter the number >with remote and open the projector ?
My Acer p 5270 projector is lock .A black box is displayed . There in > a password are putting saying . How to enter the number >with remote and open the projector ?
3 Related Answers
Anonymous
  • 201 Answers
  • Posted on Feb 22, 2009
SOURCE: enter password
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Anonymous
  • 952 Answers
  • Posted on Jul 09, 2009
SOURCE: PASSWORD FOR BIOS OFR A SATELLITE A130/A135 SERIES
some set a password for you laptop.. you need to contact toshiba for this and prove ownership for the laptop.. or... you can try to open up your laptop and short the bios battery so it would reset..
Anonymous
  • 330 Answers
  • Posted on Oct 13, 2009
SOURCE: My Toshiba boots up with Black screen with a blue
i think its power on password The Power On password is set in the System BIOS options. It prevents unwanted users from accessing the computer. By default, does not set the Power On password. If you set the Power On password in the System BIOS options you will be prompted for it immediately after you power on the Notebook PC
if you dont know the password go for a toshiba serviceing center for solve this
I forgot privacy lock password samsung chat GT-5270
Samsung Galaxy Chat GT-S5270 (Candy bar cell phone): Forgot Privacy Lock Password
Hello
Samsung Chat GT-S527 User Manual:
http://downloadcenter.samsung.com/content/UM/201108/20110825144433122/GT-S5270K_UM_MEA_Eng_Rev.1.0_110818_Screen.pdf
The only way to get back into your phone is if you Hard Reset your phone.
WARNING
If you Hard Reset your phone, you will lose all your data, contacts, photos, videos, documents, text messages, phone call logs, etc.
After resetting the device, it will be as if you just taken it out of the box. Nothing will be on the phone and you will have to re enter all your contacts, settings, applications, etc again.
Instructional video on how to Hard Reset your phone:
We have an Acer P3250 projector that keeps prompting for a password upon start-up. However, when we enter the security password provided with the unit, it says it is "invalid".
Found an earlier suggestion on this site if you don't have the provided password and also already tried 1234.
1. Turn on the projector 2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should work again
Acer P3250 will not acccept password
Svga vlp - es5 projector control key locked problem
Hello
Your projector is in security lock Enabled condition. If you have forgot the pascode . You can change the password by
Use the Menu'UP'/'Down' '<'/'>' buttons to enter the four digit pascode. The default password is "ENTER,ENTER,ENTER, ENTER". After this is entered, you can put in a new pasword. Therefore when you use this function for the first time, pleas input "ENTER" four times.
To cancel the security lock, press the Menu key, then turn OFF the "Security Lock" setting on the INSTALL SETTING menu.
If you call the customer service center because you have forgotten the password, you will need to be able to veryfy the projectors' serial number and your identity. The process may differ in other countries/regions. Once your identity has been confirmed, they will provide you a password. OK.
2helpful
2answers
Acer P3150 lcd projector password-locked which was not earlier set, security card lost. Tried to input default numbers such as 1234 and 000000 but not working. Is there any solution to solve this problem?...
I found a solution that worked for me:
3. Choose "RD Menu"
5. Turn on the projector again and it should word again
Hi. i lost my password of my Projector Benq MP610, with code 22504-15078-7347-9687. i'm looking ford to your help.
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting->Change Password 2. Press Left or Right (button). A "Password Change" message displays. 3. Enter the old password. i.If the password is correct, you can go on to enter new password.
IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __
ii.If the password is incorrect, a "Password Error" message displays. Press Up to try again or press Down to cancel. 4. Check the new password. i.Pressing Auto completes the procedure. ii.Press Up to try again. iii.Press Down to cancel the set-up and return to the on-screen menu.
I have acer aspire 5000, unable to connect lcd projector
The projector is automatically detected by laptop and then included in the secondary graphics or display as a second display component. This means that for the projector to display, you need to control it from the laptop's graphics options, i.e.
>Connect projector to laptop
> Right click on desktop and choose Graphic options.
> Choose desired option say Notebook + Display or Display alone..whichever you prefer.
It should be displaying now. Did it? Vote to let me know.
1helpful
My Acer P3150 projector is locked.Am not sure how this happened as I didn't put in any password. I need to put in a password. I don't have the security card with the "Universal Password". I need the...
3. Choose "RD Menu"
I have a BenQ Projector MP610. I lost my password and now i cannot use my projector. I get the code: 22504 13898 6789 8507. Please help...Please email me the decoded password... [email protected]
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password. IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __ Keep this manual in a safe place. ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. Password Setup Enter Password Press Auto to Confirm Press 5 or 6 to change number Press 3 or 4to move 0 0 0 0 Password Setup Do you want to use 0 0 0 0 as your password? Yes Auto No 5 Cancel
17helpful
3answers
Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
18helpful
2answers
Acer P3250 will not acccept password...
3. Choose "RD Menu"
Grand Canyon Tech
Grand Canyon Tech
