Home | HP | Officejet 5610 All-In-One InkJet Printer | Had a paper jam, fix...
HP Officejet 5610 All-In-One InkJet Printer
Problem for HP Officejet 5610 All-In-One InkJet Printer
Had a paper jam, fixed it. Now it won't print
By loriann_p_62 on Jul 03, 2009
Had a paper jam, fixed it. Now it won't print anything.
Sponsored Links
Solution #1
posted on Jul 17, 2009
Not Rated)
tumi001
Rank: Wiz  HP Expert
Rating: 78%, 8 votes
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab43
Was this helpful?
Yes
No
Solution #2
posted on Jul 03, 2009
Not Rated)
gbhuvi
Rank: Master
Rating: 85%, 24 votes
Follow these steps to resolve the paper jam. Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. This video supplements the instructions in this document. For best quality on dial-up connections, wait until the video has fully loaded before viewing. Flash Player from Macromedia is required to view this video. If needed, visit the Macromedia Web site (in English) to download and install Flash. Click here to go to the Macromedia Web site.
  1. On the rear of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Removing the rear access door CAUTION: Do not try to clear a paper jam from the front of the product. Doing so can damage the print mechanism.
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears while being removed from the rollers, check the rollers and wheels for torn pieces of paper that might have remained inside the product. Loose pieces of paper will cause future paper jams.
  3. Replace the rear access door. Gently push the door forward until it snaps into place.
  4. Press OK to continue the current print job.
    • If the issue is not resolved , continue to the next step.
    • If the issue is resolved , you do not need to continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step three: Clean the rollers
  1. Turn off the unit, and then unplug the power cord.
  2. Press in the tab on the left side of the rear clean-out door to release the door. Remove the door by pulling it away from the unit.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Cleaning the paper rollers
  4. Allow the rollers to dry completely, and then replace the rear access door.
  5. Plug the unit back in and turn it on.
Step four: Clear the jam from the automatic document feeder (ADF)
  1. Lift the cover of the ADF. Figure 3: Lifting the ADF cover
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when being removed from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. Loose pieces of paper will cause future paper jams.
  3. Close the cover of the ADF.
Step five: Reload paper and test the All-in-One
  1. Reload plain, letter-size paper in the main tray.
  2. Press the Power button ( ) to turn the product on, if it is not already on.
  3. Press Setup .
  4. Press the right arrow button ( ) until Print Report displays on the control panel, and then press OK .
  5. Press the right arrow button ( ) until Self-Test Report displays on the control panel, and then press OK . The self-test prints.
Step six: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
Was this helpful?
Yes
No
Popular Solutions for HP Officejet 5610 All-In-One
Questions and Unsolved Problems for HP Officejet 5610 All-In-One
Do you recommend HP Officejet 5610 All-In-One InkJet Printer?
Answer
Answer
this officejet printer also avaible including fax? and please send me canon all types of printer... (More)
Answer
My Hp officejet 5610v Jams (Ink carriage) while printing can you help? I previously encountered a... (More)
Answer
My HP Photosmart D7160 printer is about 30 months old. Suddenly it won't print in black, even though... (More)
Answer
I am printing a file from the computer, and it is picking up several sheets of paper at once and... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Officejet 5610 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1417
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
