Question about GE Refrigerators
Leaking GE TPS24
Side by Side GE TPS24, leaking from bottom of fridge... seems to be coming more from the freezer side but its hard to tell since one cannot see directly where the leak is coming from.
There is saddle valve on the water line. Anyone know if you turn this saddle valve Clockwise or CCW to close (turn off ) the water supply to fridge. I tried turning CCW but the valve just turns and turns....
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
  • 44 Answers
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Posted on Jun 10, 2009
  • 72 Answers
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
  • 583 Answers
SOURCE: leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Posted on Jun 12, 2009
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
My ge side by side profile tps24 is not cooling on the refrig side and the body of the refrig is hot. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
