Question about Kenmore Dryers
Dryer will not heat. Mod: 11066652500 Ser: MS2302035
  • 234 Answers
If your dryer is electric, it's most likely a thermal cut-off or the heating element. if it's gas, it's probably the thermal fuse. i do lots of these each week. 90% of the time it's what i just explained. good luck :)
Posted on Jul 08, 2009
Dryer will not heat
If it is electric, then the heating element has an open circuit. You will need to replace it.
Jan 14, 2016 | GE Dryers
No heat where is heater in kenmore mod.110.c66542500 ser.m53701943
I can't locate that model number..please recheck..most elements are located behind back panel, however, some are under front..there is a kickplate on some models on the lower front that comes off...it could be anything from a bad thermostat to low voltage causing this no heat.
Feb 08, 2011 | Dryers
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Maytag Dryers
No heat during either drying cycle automatic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Dryer wont heat
if you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Apr 04, 2008 | Dryers
Dryers Logo
95 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
