Paper tray has extended too far and I cannot push it back in - Can I remove it to start again.
You could try removing all of the paper in the drawer and use flashlight to look into where the drawer slides in. There might be some plastic "tabs" there that are designed to prevent the drawer from coming out too far. They may be preventing pushing the drawer back in and if you use something strong and thin, like a knife blade you can push the tabs (try not to break them) out of the way and slide the drawer in.
Hope this helps.
SOURCE: Paper in 3310 HP
I have had exactly the same problem. Lost heaps of paper and very frustrated. Last resort solution. Thought that the rollers that pick up paper have become smooth and not gripping paper. So waited until fault occured again (2 Pages later) did not press the ok button when asked to reload paper, and removed the back panel. Using a small artists brush dipped in metholated spirit I brushed the paper feed rollers that come in contact with the paper (not the rear visible rollers). Press the OK button and the paper feed rollers will rotate and try to pick up paper (two times) then will stop and ask for you to load paper and press OK again. Continue to press the OK button when asked, making the printer rotate the rollers while the brush is in contact with them until they have been thouroughly cleaned with the metholated spirit. I also slipper a sheet of 120 grit sandpaper dampened with metholated spirit under the rollers from the back and forced the printer to feed paper by pressing the OK button. Hold the sandpaper firm so that the rollers rotate on the sandpaper. This roughs up the roller surface. Paper feed problem seem to be fixed. Hope this works for you. Cheers Ron
SOURCE: Paper jammed in printer - need to remove paper tray
This works from HP help link in error message:
Turn off the
HP All-in-One.
Press in the tab on the rear
door to release the door. Remove the door by pulling it away from the
HP All-in-One.
Caution Trying to clear a paper jam from the
front of the HP All-in-One can damage the print mechanism. Always access and
clear paper jams through the rear door.
SOURCE: HP 952c
I'm having the same issue, when I turn my HP 952C on, it prints a half a page with characters and jibberish on it, then the middle orange light is blinking, what is the problem?
SOURCE: paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
