Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My SONY WEGA 52in Blinks red 4 times...
I checked the recently replaced lamp and made sure the door was tightly secured down, Im trying to find the fan and see if anythings off there, but i do not know where it is.
    Champion:
  • 205 Answers
Youe suggestion of fan is the right Tack. I would also suggest looking fo air filter and cleaning or replacement. The fan is located near the lamp assy. you should be able to hear it when set is on. Good luck.
Posted on Jul 03, 2009
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
My KDF-55XS955 Wega shuts off by itlself goes into standby mode and flashed red 6 times, what can this be?
Replace the lamp...should solve problem. If you recently replaced the lamp, perhaps it is not in securely or the door is not secure. Check these and the reset lamp from main menue on remote. Hope this helps.
Oct 01, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega kdsr50xbr1 blinks red 3 times
Lamp door is not secure or lamp interlock switch was damaged during lamp replacement.
Jan 19, 2009 | Sony KDS-R50XBR1 50" HDTV
No picture or sound
3 times error shows that lamp is not installed properly or lamp cover is off / not fixed.
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jan 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
