Question about Hunter Ceiling Fan Control Switch
3 speed ceiling fan, now a 2 speed
3 speed switch broke, replaced it with same volt/ amp switch. Now I have 1 high speed, 2 low speeds, no medium. Any solution?
    Problem Solver:
  • 13 Answers
It is probally a warranty.
Posted on Sep 08, 2009
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
I need to replace a fuse for the blower
First, please review this article: Where's The Fuse?
Now, for your blower fuse...
Actually, there are 2 blower fuses in your car.
Fuse #24 (15 Amp) and Fuse #14 (20 Amp) Both are located in the fuse block on the end of the dash on the passenger side.
Fuse # 24 provides power for the LOW, MEDIUM 1, and MEDIUM 2 speeds. Fuse #14 provides power for only the HIGH speed.
If your blower motor does not operate on any speed, the problem is most likely a bad blower motor or a burned-up control switch. If it only operates on HIGH, the most likely cause would be a bad blower resistor.
Apr 04, 2011 | 1995 Oldsmobile Cutlass Supreme
My A/C doesn't work on 1, 2, or 3. It only works when the selector switch is set to high. Any ideas?
There's 2 relays that control the blower motor, one runs low and medium speeds and the other runs the high speed. Replace the relay for the low and med speeds.
Jan 04, 2011 | 2008 Jeep Liberty
I have an Emerson CF705AW with a broken speed switch Dealer sold me a Westinghouse #77021 Now I get these speeds: High, low,low,off - No medium speed Wouls switch # 77020 be correct? I nered a...
Ah.
A simple Capacitor based speed control. How many places do you have to put wires on your switch? You may have mis-wired the switch, or you have the wrong switch.
How it all works is... When you turn the fan to High, or position 1 on the switch (there's L 1 2 and 3) the power goes from 1, to the capacitor, but does not go through the capacitor, but instead goes through the second (probably gray) wire directly to the reversing switch in the switch housing. When you switch to medium (or 2) both 2 and 3 positions on the switch are supposed to be sending power through both capacitors inside of the black box. Basically, you have two capacitors, when you go to medium, both are wired in parallel to each other, but on low, only one is in the circuit. Basically, the switch you have, or have mis-wired, is putting only one capacitor in the circuit at the time on medium and low positions.
Also, do not worry, so long as you only mess with these 4 wires, you cannot blow anything up, However! When you disconnect power from the fan, BE SURE that the fan is "On" when you turn the power off to ensure the capacitor discharges as you can get a very very nasty shock from the bare wires.
Sep 07, 2010 | Emerson Fans CF705AW 52" Northwind Ceiling
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
High speed setting of fan does not work
May 29, 2010 | Kenmore 72115 Air Conditioner
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
592 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
