My LG washing machine is displaying DE when I go to start it and it beeps and blinks de and does not start
The DE error or fault code is to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
SOURCE: error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then
1. Turn AC power OFF, unplug from wall
2. HAVE YOU TURNED THE POWER OFF?
3. Unscrew two visible screws on the back of the machine near the top
4. Take back lid off by pull up which will expose all the wires at the back
5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw)
6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it.
7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test.
8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch
This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
SOURCE: Our washing machine is LG Turbodrum i sensor.
My Turbo Drum Isensor is Beeping and shows dE..what is wrong and how do i fix it?
SOURCE: LG Turbo drum washing machine
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
