Question about Samsung Digimax S500 Digital Camera
S5oo Digi Cam , The camera does not power on .
The camer does not power on. I accidentally sat on camera while it was completely off with the Lens closed . I hear a crackling noise, immediately i tried to power on the lens projected out and gives 3 beeps and the LCD is blank and did not allow me to take snaps. I gently pushed the lens back in and it went litle by little. Now the lens is not coiming out while powering on and camera does not power on either . Could you please advise what has to be done.
  • Anonymous Mar 16, 2008
    Pentax Digi Cam... image are showing...Been to Deveoping studio and try asking the problem in it. One say, maybe the lens has a problem... No problem with the lcd.
  • Anonymous Mar 22, 2014
    When starting the camera, the lens cover does not fully open and has to be nudged gently. And when shutting off, the lens cover does not always fully close.
    Suspect this fragile cover was accidentally pushed in and distorted slightly?
    Any easy fixes?
  • 4 Answers
I dropped mine.
and the lens was stuck and it made those sounds.
we messed around with it
and kept opening and closing it.
and after about it an hour.
it just started working again.
Posted on Nov 11, 2007
My nikon D3100 got wet from rain...what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
My camers fell down and the shutter is not closing. The screen is fine n the images are fine too. There is a message that says close the power and try again. what do i do
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Cameras
My camer's lens is not going back in, and it's
Make like Michael Jackson and Beat it!
A bit of tiny grit can catch and stop the lens mechanism. Tapping the camera on the body or thumping it somewhat firmly & delicatelyonto a padded flat urface may help. Run a vacuum near the len and cycle it a few times after it works.
Beating these cameras is a strangely common technique.
Jul 21, 2010 | Canon PowerShot SD1100 IS Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Mavica cd-400
   The lens of camers get malfunctioning,Therefore you have to replace complete lens assymbaly.For this contact nearest SONY SERVICE CENTRE.
Thanks for using fixya.
Nov 26, 2008 | Sony Mavica MVC-CD400 Digital Camera
Hello susan herrin,
I think, you should purchase new camera now.
May 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Samsung Digimax S500 Digital Camera Logo
80 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
