The screen you are referring to is the outside screen of the tv correct?
Test your technique in small area first. It is important that you understand there is a risk with this process. It is very important that no liquid runs into the sides of the screen. This will wick into the screen and cause damage or water spots. Just a lightly dampend very soft cloth is all that is needed.
My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will...
(More)
My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will be $815.00. I decided to buy new.
I would prefer a 70"+ plasma, but with the $40k price tag. NO thanks. Anywayz.
My living area is rather large. I sit 14 feet back from the TV, so a larger screen size will suit my needs much better than the average 42-50" displays.
I have been looking at the mitsubishi 73" and 82" series C9 (73" only), 737 and 837 series. I have read several complaints on older mits models, but have come across few or none concerning the new model series listed above. I understand the lamp will need to be replaced and I guess I would deal with that problem once a year or so, if it were.
I would like some advice and thoughts regarding these models. I wonder if it would be a decent investment or would I just be entering into trouble land. If the problems are to problematic I guess I would just settle with a 65" but get the panasonic plasma, which I don't think I would have any issues with.
However, due to the living room size, I would like to settle for the larger display IF the newer series mits are quality items.
Thank you for your response.
sony kf50we610 rear projection 6 years old is still dark & blotchy after lamp replacement....
(More)
SONY KF50WE610 REAR PROJECTION 6 YEARS OLD IS STILL DARK & BLOTCHY AFTER LAMP REPLACEMENT. IS IT POSSIBLE TO CLEAN LENSES BY SELF IF NOT HOW MUCH WILL IT COST APPROXIMATELY?
my device buttons on both the remote and the front of the tv do not work. It messes with the video...
(More)
my device buttons on both the remote and the front of the tv do not work. It messes with the video feed then turns the tv off.
philips 55p8341 wont power on,but when it does come on picture flashes and starts to twist. will...
(More)
philips 55p8341 wont power on,but when it does come on picture flashes and starts to twist. will come on & cut off
