I just need a manual for my Eclipse Cd/Sterio
Hello there.
Closest I could track down is CD3424 Looks like it MUST be pretty close to 3422.
Downloads are on this page
http://www.eclipse-web.com/us/download/manual/manual/index.html
SOURCE: set up problem on eclipse cd3422
call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
SOURCE: Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
SOURCE: AUX In for Eclipse CD3422
yes it does, it's part of the CD changer plug.
Here's ->LINK<- an adapter for the iPod on EBay.
Regards
Philip
SOURCE: Help Message CD3422
purchased my car used and have no idea what the key cd is. Battery went bad so now I have no cd player. Display shows serial # of unit. Any way to fix this?
