Question about Garden
Hello, I have a Craftsman Model 917.377790 lawnmower, power-propelled, with Honda 5.5 HP engine. I replaced the belt that provides power to the rear wheels. The belt is "caged" by other parts, so I removed a clutch-like mechanism above the blade that seems to have the purpose of slipping to protect the drive shaft and engine if something stops the blade from turning. This mechanism does not appear in the diagrams or descriptions in the owner's manual, which otherwise seems complete and accurate. My problem is this: the mower blade attaches to a part of this "clutch" mechanism with two bolts. The clutch mechanism is connected to the drive shaft with a single bolt with the number 10 cast into its head. Reassembly was not difficult and no parts were left over. Now when I try to mow, this bolt either jiggles or twists loose, eventually dropping the blade and clutch assembly into the grass. I used the mower for three years without this thing coming loose. There were no lock washers or jiggle-proof washers involved. How do I keep this assembly from dropping off?
  • 749 Answers
There will be some washers that hold it together, take the cover off and have a look to see if anything needs screwing in, tighten all the screws.
Posted on Jul 03, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hello, I have a Craftsman Model 917.377790 lawnmower, power-propelled, with Honda 5.5 HP engine. I replaced the belt that provides power to the rear wheels. The belt is ''caged'' by other parts, so I...
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
Jul 03, 2009 | Garden
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
