Question about Memorex (32025638) (25 Pack) 16x DVD-R Storage Media
My DVD drive D works fine. Problem is with one particular CD.
I am trying to download pictures off a CD into my laptop. I keep getting an error msg: Please insert a disk into drive D. The disk is a Memorex DVD+R. However, I have no issue opening my other CD's so I know the problem is not my CD drive. Help plz!
  • s_rubens Jul 03, 2009
    Thank you, hotratchet for your assistance.
    I will attempt to download the CD using another pc and see if it a compatibility problem or the cd burning.
    Sheila
  • 952 Answers
This is a very common problem for all CD/DVD drives... sometimes.. there are CD-R DvD-R brands that will not work with your CD/DVD drive... its compatibility issues... another possibility is that the CD burning was bad.
Posted on Jul 03, 2009
My Dell E 1505 DVD RW drive seems to record ok, but to play direct from a CD or DVD results in garbled sound, and degraded picture. Does this sound like a driver problem, or a hardware issue? (Playbacks...
This sounds like your DVD/CD drive is going bad. If it was a driver issue you would probably get an error of "no disk in drive".
Try running diagnostics on your computer to seeif you have a hardware problem. You should have a CD that came with thecomputer that has "Diagnostics and Utilities" listed under contents.Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com andselect "Drivers and Downloads". Enter the "service tag" (serialnumber) of the computer. You can then download "Diagnostics" .
To boot from a CD disk, power on your computer and tap the key tobring you to the "One time boot menu". Insert the CD into the top CD/DVD driveand then select "Boot from CD/DVD" and hit key. Select the"Run the 32 Bit Dell Diagnostics.
If you have issues trying to boot form this CD or running the diagnostics then you CD/DVD drive needs to be replaced.
Aug 22, 2011 | Dell Inspiron E1505 Notebook
When start my laptop, get an error msg. "Grab loading 1.5, please wait.. grab loading error 17. and i can not boot from cd / dvd too..in HP nx9010. Plz help me.
This grub loading error 17 means that the file system type could not be recognised you should be able to boot from a cd make sure the cd or dvd drive is enabled as the first boot device in bios
I hope this helps
Andrew A
Apr 01, 2011 | HP Compaq Business Notebook NX9010
I want to restore to factory state but boot cd won't work
I think your hard drive which is a SATA drive, needs to be formatted specially for Vista.
you need to find out the make and model of your hard drive,and then you can download a hard drive formatting utility program from the hard drive manufacturers website.
The hard drive is accessed from under the keyboard on this model.
Jan 30, 2009 | NEC Versa VX Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Disk Error, CD only
It may not recognize the CD if it is a copy. try an original CD and see if it works.
Nov 30, 2008 | Onkyo DV-C601 Multi-disc DVD Player
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
I get an error 6 the handle is invalid
While running setup or autorun file directaly from the CD error msg comes as:- The handle is invalid
Email :- kumar.sanjit@mahindra.com
Jul 24, 2008 | Computers & Internet
Computer is not recognizing my cd/dvd drive
Umm..Try install all the drivers of your system. the CD was enclosed in your system. if ever the cd is not work you should download the driver of your system.
or After installing a new windows do not restart your system until you finish all the driver installation and also the driver of your CD/DVD.
I 100% pinpoint that the your CD/DVD needs a driver. so install and you'll be fine.
Jan 18, 2008 | Dell Inspiron E1705 Notebook
360 won't read update disc
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Dec 16, 2007 | Microsoft Xbox 360 Console
Memorex (32025638) (25 Pack) 16x DVD-R Storage Media Logo
59 people viewed this question
Top Memorex Electronics - Others Experts
Stu Morris K
tdk1988
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
