Question about Jacuzzi Home
Tank top toilet bowl gasket needed - Jacuzzi Home
  • 224 Answers
You can pick these up at any hardware store. It's called the tank-to-bowl gasket and should either come as one piece or as an assemblly with tank-to-bowl hardware.
Posted on Jul 04, 2009
Toilet tank leaking
Hello David McInnis,
There are Three basic opportunities for leaks from the classic TOILET TANK DESIGN (separate BASE & top-tank)... around the FLAPPER VALVE alone... Typically the flapper valve & two hold-down screws. These CANNOT be repaired without removing the entire tank. GREAT CARE should be used to not FRACTURE
the mated surfaces by OVER-TIGHTENING.
This is a great time to FRESHEN UP all the
Perishable gaskets & seals... and while I NEVER advocate using any ABRASIVES on gloss finishes... Pumas stone seems to be the FINAL TOUCH in a total renewal
(to REMOVE the built up (very unsightly
TOILET BOWL RING...
Amazon com toilet bowl pumice stone
ADDITIONAL PARTS:
- Water fitting to FILL VALVE (compression fitting).
- FILL VALVE through tank (gaskets)
- Flapper Valve base, gaskets & bowl interface ring
TO Make sure all the surfaces are clean an firmly
positioned and it is not LEAKING anywhere... place
clean dry paper on the floor behind the bowl
(under the tank).
EACH/EVERY drop will leave a mark...
Do NOT over-tighten any fittings!!!
If the WALL VALVE is less than NIMBLE... also a great opportunity to UPGRADE TO A QUARTER TURN
BALL VALVE... A little shopping will find you EXACT VALVE CONFIGURATION...
Hope this helps.
LASCO 04 3809 Toilet Tank To Bowl Bolt Kit Brass Bolts with Washers Hex...
Fluidmaster 6106 2 3 4 Inch Tank to Bowl with Three Bolts and Gasket...
BrassCraft G2CR19X C1 1 2 in NOM Comp Inlet 3 8 in OD Compression Outlet...
Kohler 1068031 Fill Valve Flush Valves Amazon com
Apr 02, 2017 | Plumbing
How to install a toilet
Things needed; set of johnnie bolts, wax ring, water supply tube, open end wrenches.
insert the flat head of the johnnie bolts into the groove of the floor flange so the threads are pointed straight up. Install the wax ring directly onto the floor flange. Set your toilet bowl down on top of the wax ring so the johnnie bolts stick up through the holes at the bottom. Install the washers and nut to secure the toilet to the floor. Depending on the type of toilet, you may or may not need to manually install the tank to bowl gasket and tank to bowl bolts. Set tank onto bowl and tighten the bolts. Usually a 1/2" wrench. Do not over tighten because the porcelain will break. Install the water supply to the bottom of the tank and then tighten it to the water shutoff valve. Install the seat, and your all set.
Apr 09, 2014 | VitrA Home
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
Jan 16, 2014 | American Standard Cadet 3 Right Height...
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
I have 5 kohler pressure assist toilets with flushmate 503 series tanks in my home. Several of my bowls have minimal to no bowl rinse. My water pressure is more than adequate. I recently changed a...
There are two holes in the top of the bowl where the tank attaches. As you indicate, one hole delivers water to the jet at the inlet to trap passageway, and another smaller hole to direct water to the rim.
I have seen in some cases the gasket that seals the tank to the bowl block the smaller rim-fed hole. All you need to do is knotch the gasket where the hole is located and re-install the gasket so the knotch is located over the hole. If you have any other questions please call the 800 phone number on top of the Flushmate.
May 19, 2011 | Kohler Home
I have a pegasus 164-146. need a toilet tank gasket that the tank sits on to connect to the bowl. Cant find one anywhere
You need a spud washer.
Or a gasket and bowl kit.
Or toilet tank gasket
Or tank to bowl gasket
1) Fixya answer from last year says Lowes/ Home Depot sells part
Home Depot sells Pegasus toilets
http://www.fixya.com/support/t5647268-need_tank_bowl
2) Plumbing supply dot com has selection
http://www.plumbingsupply.com/tank_gaskets.html
http://www.plumbingsupply.com/closetspuds.html
Company also has contact page:
http://www.plumbingsupply.com/email.html
3) http://www.plumbingworld.com/toilettankgaskets.html
4) If gasket is not torn apart, you can probably seal it again using rectoseal on both sides of washer. This is how I fix problems. Buy rectorseal from home center.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Pegasus Technologies Two-Piece Round...
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Aug 03, 2009 | American Standard 2002.014 - Champion4...
I need torque specs.for head and centerhead when replacing new gaskets.
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
Mar 22, 2009 | Kohler KOHGP51487 Authorized Original...
Home Logo
208 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
