Question about Peg Perego Vespa Scooter
Turn signal switch needs replacement
Unable to activate left turn signal ...where can you get a replacement switch?
    Problem Solver:
  • 16 Answers
You can find your closest vespa dealership here:
http://www.vespa.com/
You can order the part there.
Otherwise ebay usually have them
Posted on Aug 23, 2009
Turn singles and hazards are not working on my 2001 deville
I would replace the turn signal hazard combo switch.
Nov 28, 2016 | Cars & Trucks
Turn signal relay 2007 Avalanche ltz
There is no turn signal relay or flasher , Computer controlled by the BCM - body control module .
Turn Signal/Hazard Lamps
When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
This is something best left to a qualified repair shop that has a professional type scan tool . Could need new BCM , which would need programming . Scan tool would be able to check switch inputs for BCM .
May 22, 2016 | 2007 Chevrolet Avalanche LTZ
My right front turn signal not working the bulbs are good and so is the fuse but I don't have fire going to them it's a 2010 chevy 2500hd
You don't have fire , never heard it called that before ! Battery voltage , power but never fire ! An open CTSY fuse located in the I/P fuse block will affect the operation of the right front turn signal only
Turn Signal/Hazard Lamps When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
Ground is applied at all times at G201 to the turn signal/multifunction switch. The turn signal lamps may only be activated with the ignition switch in the ON or START position. When the turn signal/multifunction switch is placed in either the TURN RIGHT or TURN LEFT position, ground is applied to the body control module (BCM) through either the right turn or left turn signal switch signal circuit. The BCM then applies a pulsating voltage to the front and rear turn signal lamps through their respective control circuits.
Jun 25, 2015 | Cars & Trucks
Unable to locate the flasher for Hazard/Turn signals
Its part of the hazard flasher switch , or should I say the switch is part of it ! Where is your flasher switch located ? In the radio bezel ? the trim plate around the radio if you don't know what a bezel is . Oh yea , to answer you question , yes turn signals do go through it !
Mar 09, 2015 | 2000 Ford Focus
I have a 2005 325ci bmw the hazzard light not working neither turn signal .
The simple, and most likely, cause of this problem is a blown fuse in the turn signal circuit. Normally, the turn signal lamps are activated by a single-pole double-throw switch circuit on your 325ci's steering column. That switch is also called turn signal switch and, as you know, you activate it by pressing up or down on the turnstalk (the lever usually on the left side of the steering wheel).
The hazard light circuit is a double-pole single-throw circuit that gangs the right and left turn signal circuits into one and then activates the front and rear signals as your 325ci's hazard lights.
Since they use the same circuits, the fuse is common to both and if it is blown then neither the turn signals nor the hazard lights will work.
Jan 03, 2015 | Cars & Trucks
Tiburon 04, left turn signal lights stay on once activated by either turn switch, hazard light switch, or alarm. Can sometimes get them to go out by using right turn switch position, or playing with hazard...
replace the turn signal 'Clicker' also known as the turn signal relay. Most likely the problem unless you have a really wierd electical issue that will be hard to isolate...
Peace,
Jan 23, 2010 | 2004 Hyundai Tiburon
Turn Signal Switch where is it located
Here's a video that will show you where it is and how to replace it.">
Jan 06, 2009 | 2000 Pontiac Sunfire
Peg Perego Vespa Scooter Logo
465 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
