Question about Apple iPod MA446LL/A MP3 Player
Ipod 30 gb
Hi i have a 0 gb ipod and the screen is showing disk mode restore using itunes i am trying to restore bur it is telling firmware corrupted what should i do
    Scholar:
  • 46 Answers
You'll need to reset and then resync the device. To do a reset you turn the lock on and then off and hold down the center select and menu buttons, at the same time, for five seconds until you see the Apple logo appear. Then, plug the unit into your computer and sync. In iTunes you'll want to choose to restore the unit. That will erase and then restore your syncronized data, as well as update the firmware.
Posted on Nov 10, 2007
  • Not Available Nov 10, 2007
    Oh, I should note, this happens when you remove the unit while it is still syncronizing and "disk mode" has been enabled. To prevent it from happening again, make sure to open Windows Hardware Manager (it's the little green arrow that says "Safely Remove Hardware" in the System Tray next to your clock) and stop the device before unplugging the cable.
Ipod classic manual
Your ipod may be corrupted and will need to be wiped and restored.
First of all try another lead to connect your ipod to pc.
Also look inside bottom of ipod to check no bent pins in ipod dock.
Also reinstall itunes incase of program corruption.
If still not working you will have to put ipod in disk mode.
Switch ipod off then switch hold button on and off then hold down centre putton and bottom pause button until TICK appears.You are in Disk mode.
Go to file explorer and right click your ipod if shown,Chose FORMAT then chose restore device defaults and restore. Once formatted open itunes and connect ipod with good lead.Ipod can now be restored from backup or a clean restore can be done
Aug 23, 2014 | Apple 160 GB iPod Classic (Silver) +...
Ipod touch 3g has a white screen - any way to bring it back up?
Hi mickhon...
White Screen of Death
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Sep 17, 2011 | Apple Ipod Touch 8 GB 32 GB 64 GB 3rd...
Ipod 80gb silver, when i turn it on it has a RED CIRCLE WITH A RED CROSS INSIDE ON IT AND UNDERNEATH THAT IT TELLS ME TO GO ON .... www.apple.com/support/ipod and i've tried this but it was no help. The...
connect the ipod to pc
start itunes
when it detects the ipod in recover mode
click on restore button to restore the firmware
it will download and reinstall the firmware
if it isn't detected in recovery mode then simply click on update button when it is detected normally in itunes.
Mar 05, 2011 | Cameras
IPOD not restoring
Download the latest firmware from apple and update the firmware and it will be OK
Oct 23, 2009 | Apple iPod touch Second Gen (8 GB,...
When I restore my ipod it, it never really restores
try to format your ipod hardisk. then restore it.
Jul 22, 2009 | Apple iPod MA446LL/A MP3 Player
120GB classic ipod is corrupt
You will want to attempt to force the iPod into disc mode then restore using iTunes. With the iPod in disc mode, iTunes should show the iPod. You will have to restore the iPod to resolve the issue of corruption though. Please let me know if this does not resolve your issue. :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 17, 2009 | Apple iPod classic MP3 Player
My Apple iPod Video 30 GB Black MP3 Player is locked i cant unlock it
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
May 07, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30 gb hanged
you can try by putting it in disk mode. press down firmly menu button and reverse or forward that should take u into disk mode and u can trouble shoot the ipod that way.
Apr 25, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod help
i ahve been throught the unable to find the track thing but i am sure my problem was different cause fixing mine involved actually hitting it
but it sound like it was miss partitioned i would use windows disk management software after and possible before itunes' restore utility
Mar 27, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30 gb
Reboot your ipod in Disk Mode then try itunes again. Also make sure your itunes is setup so it boots up when it sees it. (that way you know it sees the device)
As far as seeing it "usb mass storage" that is a good sign. You maybe able to recover items with a good friend called LINUX which is compatable with apple software.
Disk Mode:
Hold the select and menu button and once the device turns off hold the select and play button and hold it until it says Disk Mode.
Once booted in Disk Mode try to connect via usb.
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
73 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
