ViewSonic VP930b  19" LCD Monitor
Problem for ViewSonic VP930b (Black) 19" LCD Monitor
My VP930B monitor screen is so distorted that you
By pansylyn on Jul 03, 2009
My VP930B monitor screen is so distorted that you can barely see what is there. Once in a great while the picture will suddenly be perfect! The monitor and tower both have a DVI-i dual connectors , but my cable has DVI-D singlelink. Could this be the problem? Linda
Best Solution
posted on Sep 15, 2009
Very Helpful)
Mergatroid
Rank: Wiz
Rating: 84%, 213 votes
Could be. You can try using the VGA port just for a test. Connect it to a friends computer or a laptop. also, there is the following solution for unusual problems on the VP930B:
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for ViewSonic VP930b 19" LCD
Questions and Unsolved Problems for ViewSonic VP930b 19" LCD
Do you recommend ViewSonic VP930b (Black) 19" LCD Monitor?
Answer
Answer
waving a little in the scree.
Answer
power indication is green.no display
Answer
I just received a rebuilt VP930b monitor and there is no true black, so the screen color's wrong
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
