Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
We have a one drawer type dishwasher in our new motorhome and no pamplet seems to be enclosed. Could you please tell me how to lock it!! I does come pen when traveling! thank you.
  • 224 Answers
Most dishwashers either have a latch located at the top that you must slide to the right, or have a mechanism that should lock it anytime the door is closed. Look at the top of the dishwasher door, if it's just a handle then it has the mechanism. Look at the handle for the door. There should be a lever within the handle that disengages the latch. There could be something broken within the door mechanism. You should see the catch on top of the door and receiver on the underside of the top portion of the dishwasher housing.
Posted on Jul 03, 2009
Fisher paykel dishdrawer lid will not stay locked
Assuming this is happens with only one drawer - most likely controller is recongising some sensor problems. If the water inlet is faulty then it is waiting for water to get in. Alternatively, the sensor that tells it the drawer is closed suddenly misbehaves and confuses the controller which stops the cycle.
Feb 13, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
How do I remove the drawer in a fiisher and paykel 6031 dishwasher. I only have one drawer and it is leaking water. Want to check out if there is a leak behind. think it may also be the top seal. if so...
There are two tabs, one on each side that will release the drawer to slidr forward. I have enclosed a photo of the square tab on one side. press both sides in and pull the drawer toward you . There shouls be a wire bale on the rear that hods the water lines. If these are interfering with the seal that will be the cause of your leak.7_3_2012_2_56_28_am.jpg
Jul 03, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Top drawer of dishwasher will not turn on says its locked. Could you please tell me how to unlock.
you have to push the pro cycle for about 10 seconds and that will cancel lock message.
Apr 04, 2011 | KitchenAid KUDD01DSSS Built-in Dishwasher
My top drawer won't start. it doens't seem to
Most likely problem is the drawer close sensor mounted at the back of the housing is faulty. The lock function on these is electronic and unless the controller detects the drawer has closed it will not start the lock motors.
You will have to replace the sensor to make this work. There is a possibility the drawer may have come off the rail and therefore not travel to the end. This can be checked by inspecting the travel of the drawer.
In any case you will have to take the drawer out from the housing. see page 7 step 2 of the installation manual for this. This is for a later model but your model should be similar.
Jul 02, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
May 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer does not stay shut
open door and look under countertop to see if your bolts are tight to hold your dishwasher in place?
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel drawer dishwasher is stuck open and will not close
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
Nov 14, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a top drawer and a bottom drawer type. My
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Oct 28, 2009 | KitchenAid Dishwashers
The Fisher Peykel dual drawer dishwasher : the top unit LED is off and the setting for length of wash is not lit up and is not functioning. There is power to unit because when I hit the lock button it...
can you see a small lock inside the display panel??? the control may be locked. another issue might be a broken heater plate, not a very home owner freindly part to change( heater plate has a fuse inline that would kill power to function
Nov 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
165 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
