Rtl8168/8111 pci-e lan failing
I built a new computer from scratch ordering all of the parts seperately. I know it is all compadible because the computer works fine, with exception to connecting to the internet. I have a Realtek rtl8168/8111 pci-e Gigabit Ethernet NIC (NDIC 6.0) and this message pops up ''This device cannot start. (Code 10)''
I have installing drivers, uninistalled/reinstalled this device and more. I would appreciate the help if anyone can elaborate on the issue.
ps: I'm running vista 64 bit, ultimate
  • 390 Answers
Hi
i think the issue is more to HW than SW
just a thought but, place the ethernet card in the slot properly but donot put in the screw to attach it to the cabinet and check to see if the card is getting detected
also try checking if te card works on some other machine with either XP or some other
just a hunch though
cheers
pls rate if it was any help
Posted on Jul 03, 2009
Computer ethernet port
Try different cable, modem, router, but seriously if its the actual lan connector on the motherboard that is bad, buy a new motherboard.
Check the warranty on the PC.
You can always but a lan card, see what you have for PCI slots on your motherboard and buy a card from Newegg.
It is not worth fixing an onboard lan.(ethernet) one that's built onto the board.
Look at these.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100006688&isNodeId=1&Description=ethernet+cards&x=0&y=0
Mar 04, 2013 | Compaq Computers & Internet
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
How to repair lan if it is keep blinking without any lan wire
If it is onboard lan you would need to send the entire motherboard for LAN repair which is an expensive process.however if it is a LAN card that you have connected seperately in PCI slot, then replacing the same is a much cheaper, easier and better option.
Jan 08, 2012 | Intel D945GTP Motherboard
I installed new XP on my comp. and cant get to the internet ... shows that there is connection but cant get in .... and internet explorer say what you can try ... Diagnose Connection Problem ... then it...
hi! I think u need to install drivers in your PCI internet/LAN Card or built-in LAN
Please check the brand of Motherboard if it is built-in or the PCI Card Brand. and browse it in the net with another PC with the NET connection, to the manufacturer websites. and search it with corresponding model of the motherboard or the PCI Card. and download the Driver's and save to USB and paste it to ur PC and install it.
if this tips is helpful. please rate it. thank you.
Feb 21, 2011 | Computers & Internet
I dont know he model of my motherboard, how do i will identify it?
Run a detection program. PC Wizard is in my opinion the best and it will provide you with a lot of extra data.
http://www.cpuid.com/softwares/pc-wizard.html
Jun 20, 2010 | Computers & Internet
In built lan in pci bus is not working. Which lan card i can insert in pci slot?
Any brand that is made to fit in in a PCI slot. Try Best buy or Tigerdirect.com. Also, go into your bios settings when computer 1st starts and shut off the built in lan on your motherboard (see computer manual or online support for your brand)
May 06, 2010 | Asrock 775i65GV Motherboard
CULVER, Trigem Computers ver 2.05 no lan driver
you will need to know the mother board manufacturer and model mumber to get that. if you cant get that info just get a pci nic card. and dont worry about the on board LAN. they are 10 to 30 dollars
Jun 25, 2009 | Computers & Internet
When I activate LAN, not able to connect to internet /share files
change your media type auto to 10 mb full duplex
you found it in your lan card properties
Apr 05, 2009 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Home networking.
do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Out of 4 networked computers, 1 computer has stopped networking, and the light on the Linksys for computer #3 confirms this because it's light is out. How do we fix this?
It could be one of two issues. The cable has gone bad. Replace the cable. Or, the LAN port on the computer has gone bad. Replace the LAN port. If it's a built in LAN port, just add a PCI one; they can be purchased for under $10.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
