Question about Tools & Hardware - Others
Electric sander sparks and smokes - does not run at full speed - what could be the problem? Also have a grinder doing the same thing
  • 952 Answers
Its possible that the electric motor brush is already worn out. try to have it changed..
Posted on Jul 03, 2009
My sander doesn't run at full speed - it's slow. I've changed the carbon brushes but this hasn't helped.
if it sparks a lot at the brushes , then there is an armature or winding fault
sanders are cheap so junk it and upgrade
Feb 25, 2016 | Makita BO4900V Half Sheet Finishing Sander
My Festool orbital sander has suddenly omitted a puff of smoke from the top and has stopped working
If you have shorting again by trying replace the capacitor but if it is not working try to turn a little the fan insite there is a collector burned out the commutator of the armature . if the machine was too hot replace both the armature and electric field if the lasting is not to great , ask yourself is my machine not to old for repair ?? because of the costs of the spare parts and the housing and remaining part. try out if the machine was not running this connect the cable again switch it on and carefully use a small screwdriver through the ventilation slot over but do not be surprised if he comes quite sparks and run.
The electric statorfield can on one coil side be broken
Jan 30, 2014 | Festool 571794 ETS 150/5 EQ 6-in Random...
Skil model970
Skil 970. 9" Disc Super Duty Grinder type 1. Electric 110V. $45.
It's not a good sander.
More details about the best disc sander go to the link
Best Disc Sanders For Sanding In 2018
Nov 25, 2012 | Skil Tools & Hardware - Others
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
I have this grinder, when i plug it in and turn it on it starts smoking and has an electrical burning smell. Is this the brushes going out? and it doesnt seem like it is going full speed. Is there a fix...
Brushes usually won't start smoking on power up. Sounds like shorted windings. I would recommend a new unit rather than risking a fire. I would also recommend a professional brand if it is something you will be using a lot. In the long run it will save you money.
Jun 13, 2010 | Craftsman Professional 26437 75 amp 10000...
Milwakee grinder 6140, heats up runs slow and makes noise
check the commutator bearing and also to see if armature rubbing field. Let me know if you need more help. You can get a breakdown at Milwaukeetool.com
Mar 15, 2010 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
Sparking bruch
most likely the carbon brush is worn out and need to be replaced.
Jan 15, 2009 | Dewalt D28494N 7" and larger Electric...
Tools & Hardware - Others Logo
342 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
