Question about Refrigerators
I have a Hobart Q2 refridgerator not cooling
I have a Hobart Q2 refridgerator where the thermostat was showing 69 degrees farenheit, and inside the cooler is actually 54 degrees. Do you have a troubleshooting manual?
Sea Breeze
  • 4655 Answers
SOURCE: VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Posted on Oct 23, 2007
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
  • 23 Answers
SOURCE: refrig side won't cool past 55 degrees
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Posted on Dec 29, 2008
SOURCE: Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Posted on Mar 02, 2009
VOTIT
  • 2071 Answers
SOURCE: refridgerator 46 degrees farenheit freezer 26degrees farenheit
This a symptom of faulty defrost heater,replaced this heater so it works normal again.
Regards:
VOTIT
Don't forget to rate:
Posted on Jul 07, 2009
I moved into a house with this thermostat but I don't have wifi, is there anyway to get the thermostat below 69 degrees?
didnt specify what stat but if you dont have internet or the app or doesnt have a manual override need to change to a conventional stat
Apr 29, 2018 | Heating & Cooling
Display shows LLL
PDF]Chronotherm III 7 Day Programmable Thermostat - Honeywell
https://customer.honeywell.com/resources/techlit/.../69.../69-0352.pdf
O I" O 0. HEAT M10 COOL OF ow to operateyo. This Owner's Guide will show you how to get the most benefit from your new thermostat. Your new Honeywell ...
Sep 13, 2015 | Cars & Trucks
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
The thermostat is set on heat (70 degrees). My inside temperature on the display keeps saying 70 degrees yet the heater continues to kick in. The thermostat was just recently replaced and it has new...
Most thermostat have a dead band setting that you can set yourself.
Maybe your dead band is set 1 or 2 degrees above setpoint so unit would run to satisfy deado band
Jan 07, 2018 | Honeywell CT87B ROUND HEATING&COOLING...
Hi I honeywell,rth63oo b electronics thermo stat how do o change the accuracy from + - 1% to + - 3% Thankx
The following are the two manuals for ths product, I looked briefly and didn't see an answer to your wuestion. If you want to change the number of degrees between heating and cooling operation from 1 to 3 degress that can be found in the operating manual, under programming. 69-1723 - RTH6300B - Programmable Thermostat Operating Manual
69-1717 - RTH6300B Programmable Thermostat Installation Guide
Jul 20, 2010 | Heating & Cooling
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
Refridgerator 46 degrees farenheit freezer 26degrees farenheit
Regards:
VOTIT
Jul 07, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
Refrigerators Logo
359 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
