Question about Canon Office Equipment & Supplies
Canon lc 2060. REC. PAPER JAM I replaced solenoid, clutch, pu roller and sep pad and still won't always feed. Joe
    President:
  • 392 Answers
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Posted on Jul 03, 2009
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
IR5570 jamming from paper deck #2 but having a 0201 jam code what possible solutions ....changed the feed sep and pu tires and also replaced paper deck #2 registration rollers going into the duplex...
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Jan 27, 2010 | Canon Office Equipment & Supplies
Hi, i am getting a rec paper jam message, I replace clutch, pu roller, solenoid and sep pad on tray 2 this is a Canon LC 2060
Hi
1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
3. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
4. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
5. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
6. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
7. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Canon LaserClass 2060P Plain Paper Fax
Supply rec. paper when i insert paper then rec. paper jam
Your copier feed roller clought is not active wash it and then solve
Jun 11, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper feeder not pulling paper from drawers, it does pul from the drawer but then when the second stage is supposed to pick up it does not and indicates a jam.
Have you replaced the paper pick up & paper feed & paper sep. rollers? If not try to clean the rollers with Wd-40 or simple green. If the copier works better, you will need to replace the rollers. Good Luck
May 17, 2009 | Canon CLC 1120 Color Copier
Went we want to print something it's says that the paper is jam
This could mean a couple of things, it colud be that you really do have a jam (sometimes just a small piece of paper hidden in the paper path) or if you have a duplexor on the unit, paper likes to hide in there... all else fails, replace the feed rollers and sep pad if it has a sep pad... Next time it's pretty helpful to put the type and model of printer you have if you want a straight answer... hope this helps...
Jul 31, 2008 | Office Equipment & Supplies
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
52 people viewed this question
old marine
old marine
