Question about Bose Lifestyle 38 System
I am attempting to connect a computer monitor to my bose lifestyle 38 system. The monitor has an HMDI input
I think that will be hard to do as I own an AV38 and there is no HDMI feature on my BOSE SYSTEM. I had to use the AV inlet. The AV48 DOES have the HDMI feature.( Unless you have a much later model AV38 that has the HDMI feature.
Posted on Jul 24, 2009
How do I transfer music from my lifestyle 38 to a newer unit
Suggest you consult with BOSE
My inference from
https://worldwide.bose.com/productsupport/assets/pdf/guides/lifestyle/en/ig_en_ls18_series2_ls28_series2_ls38_series1_ls48_series1.pdf
26241829-avo1hezaf1vg34ez5fnknftc-5-0.png 1. You should be able to backup using the DATA Connect port.
Not sure of the pin configuration and external device.
2. You should be able to connect using Optical-Out port to Optical-In of new device (if it exist)
Jul 20, 2016 | Bose Lifestyle 38 System
Tip
Reset Bose LifeStyle 38 VChip Password
Bypass or Reset Bose LifeStyle 38 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 38 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Bose LifeStyle 38 Video Mode
on May 02, 2010 | Bose Lifestyle 38 System
Tip
Download Bose LifeStyle 38 System Manual
Have you misplaced your Bose LifeStyle 38 Owners Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Users Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on May 02, 2010 | Televison & Video
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Tip
I hope that helps.
Tip
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Dec 15, 2008 | Bose Lifestyle 38 System
Bose Lifestyle 38 System Logo
247 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
