Question about Canon LaserClass 2060P Plain Paper Fax
Hi, i am getting a rec paper jam message, I replace clutch, pu roller, solenoid and sep pad on tray 2 this is a Canon LC 2060
    Brigadier General:
  • 8,619 Answers
Hi
1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
3. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
4. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
5. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
6. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
7. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 03, 2009
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Paper jam
Have you tryed replacing replacing the pick up rollers? Also make sure that the paper guides are snug against the paper.
Jul 06, 2013 | Brother MFC-7820N Printer
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
IR5570 jamming from paper deck #2 but having a 0201 jam code what possible solutions ....changed the feed sep and pu tires and also replaced paper deck #2 registration rollers going into the duplex...
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Jan 27, 2010 | Canon Office Equipment & Supplies
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
Canon lc 2060. REC. PAPER JAM I replaced solenoid, clutch, pu roller and sep pad and still won't always feed. Joe
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Jul 03, 2009 | Canon Office Equipment & Supplies
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Lift lid to continue printing
OK, Based on the information provided I think I can offer a solution. They are getting open and close top cover and the unit will print a few pages and stop. I will assume the machine is indicating paper jam (although not confirmed) and no paper is in the machine. A maint. kit was recently installed.
The problem is likely the separation clutch.
The clutch is located in the paper tray (tray 2 and tray 3 if installed) just to the right of the roller.
Heres the test:
Remove the roller and the clutch. The clutch will slide off the shaft after the roller is removed.
reinstall the roller.
Run a paper path test for the tray you removed the clutch from or just print something multi pages.
If the machine prints more then the few pages at a time without giving the error we have solved the problem.
You need a Sep. Clutch.
NOW PAY ATTENTION:
You may get a jam error printing without the clutch installed BUT there will be paper in the printer. This is because without the clutch the machine may feed more than one sheet at a time. but if the paper is making it into the machine the clutch is the issue.
Hope this helps
Mar 20, 2009 | HP Office Equipment & Supplies
Xerox workcentre pro 765 paper jam
On this model, the roller assembly may need to be replaced. The part comes with a complete set of rollers and a new clutch on the end of the shaft. This clutch is important to the operation of paper feeding.
The other area that can be a problem is a solenoid that actuates the clutch. If the solenoid does not operate you can have paper jams.
The supply voltage for the paper solenoid clutch is supplied by the mother board. If this is the case, a new mother board needs to be installed.
The paper trays have springs under the metal tray, sometimes stretching these springs just a small amount can help to increase the pressure to the paper feed rollers. In time, they can get weak and with a full tray of paper, the paper will not touch against the feed rolls.
If possible, sometimes using a light weight piece of sandpaper, scrub the rollers to break the hard rubber glaze. This can give better grip to the feed paper.
On this machine, there is a side door to on the right side. It opens to clear a jam. There is a black door inside that flops out. If this black door is not hinged, and you can hold it in you had in any side position or comes off and in your hands, this black door needs to be replaced. This door has rollers, which help drive the paper.
For safety reasons, a service call may need to be placed on this model machine.
This is a very good model, customers prefer this machine because of its uniqueness in preforming jobs different from even the newest models.
If you wish to keep this model and the manufacture continues to support the product, you can make a good investment on this model.
If you decide you wish to keep this machine, pay the price, and get the service work done properly by a trained service representative.
Above all, be safe and enjoy your product.
Good luck.
Jul 27, 2008 | Xerox WorkCentre Pro 765 Laser Printer
Canon LaserClass 2060P Plain Paper Fax Logo
76 people viewed this question
old marine
old marine
